Help help help cisco routing
17 years 6 months ago #23531 by skepticals
Do a 'show run' on the router and then copy and paste the output here.
17 years 6 months ago #23533 by vitamin
Building configuration...
Current configuration : 1024 bytes
version 12.4
hostname connetions
boot-start-marker
boot-end-marker
enable secret 5 $1$GrWs$UgEyD3sjnthkIN8MJDa2g1
enable password xxxxxxxx
no aaa new-model
resource policy
ip subnet-zero
no ip routing
no ip cef
no ip dhcp use vrf connected
interface Ethernet0/0
ip address 192.168.1.254 255.255.255.0
no ip proxy-arp
no ip route-cache
full-duplex
no cdp enable
no mop enabled
interface Ethernet0/1
ip address 192.168.2.254 255.255.255.0
no ip proxy-arp
no ip route-cache
full-duplex
no cdp enable
ip classless
ip route 0.0.0.0 0.0.0.0 Ethernet0/0
ip route 0.0.0.0 0.0.0.0 Ethernet0/1
ip route 192.168.1.0 255.255.255.0 Ethernet0/1
ip route 192.168.2.0 255.255.255.0 Ethernet0/0
ip http server
control-plane
line con 0
exec-timeout 0 0
line aux 0
line vty 0 4
password xxxxxxxx
login
no process cpu extended
no process cpu autoprofile hog
end
17 years 6 months ago #23534 by Dove
end
Remove the above line, it should work.
no ip route 0.0.0.0 0.0.0.0 Ethernet0/0
no ip route 0.0.0.0 0.0.0.0 Ethernet0/1
Dove
17 years 6 months ago #23537 by vitamin
Nope. Still does not work. Ping just reports "Request time out"
Any ideas?
17 years 6 months ago #23538 by Dove
Oops Sorry...I missed out...
Your config required bit correction as below. Give the below commands
no ip route 192.168.1.0 255.255.255.0 Ethernet0/1
no ip route 192.168.2.0 255.255.255.0 Ethernet0/0
ip route 192.168.1.0 255.255.255.0 Ethernet0/0
ip route 192.168.2.0 255.255.255.0 Ethernet0/1
Dove
17 years 6 months ago #23542 by skepticals
no ip routing
Doesn't that turn off IP routing regardless of his settings?
