Help help help cisco routing
17 years 6 months ago #23594
by vitamin
Replied by vitamin on topic Re: Help help help cisco routing
Thanks guys. I will try it with crossover cables.
At the moment I have the router then connected through switches at the end of each interface are two pc's.
The switches are basic switches no managment :roll:
17 years 6 months ago #23595
by vitamin
To be honest its worse now as I cant ping the other interface of the router.
From within in the router or from dos on a client pc connected to that interface through my switch. I could do all of this before the reset.
17 years 6 months ago #23597
by vitamin
It's working now!!! I ran the following commands and everything slotted into place.
[code:1]interface ethernet 0/0
ip address 192.168.1.254 255.255.255.128
no ip proxy-arp
no ip directed broadcast
no shutdown
speed 10
full-duplex
interface ethernet 0/1
ip address 192.168.2.254 255.255.255.0
no ip proxy-arp
no shutdown
speed 10
full-duplex
no ip proxy-arp
no shutdown
speed 10
full-duplex
no ip proxy-arp
no shutdown
speed 10
full-duplex
- skepticals
- Elite Member
17 years 6 months ago #23604
by skepticals
Replied by skepticals on topic Re: Help help help cisco routing
Sounds good. Let me know if you have any more questions.
Can you post your final config?
