Help help help cisco routing
18 years 11 months ago #23569 by skepticals
[code:1]write erase[/code:1]
Then
[code:1]reload[/code:1]
18 years 11 months ago #23572 by vitamin
cool
I have done the reload.
So I have been taking to a Router> promt.
18 years 11 months ago #23575 by skepticals
Okay. Start with the basics:
conf t
hostname cisco2600
ip route 192.168.1.0 255.255.255.0 Ethernet0/0
ip route 192.168.2.0 255.255.255.0 Ethernet0/1
int e0/0
ip address 192.168.1.254 255.255.255.0
interface Ethernet0/1
ip address 192.168.2.254 255.255.255.0 [/code:1]
18 years 11 months ago #23578 by vitamin
o.k now do i need to save that at all>?
[code:1]Building configuration...
Current configuration : 641 bytes
version 12.4
hostname cisco2600
boot-start-marker
boot-end-marker
no aaa new-model
resource policy
ip subnet-zero
ip cef
no ip dhcp use vrf connected
interface Ethernet0/0
full-duplex
shutdown
full-duplex
ip classless
ip http server
control-plane
line con 0
line aux 0
line vty 0 4
end
So that is my config at the present moment in time.
18 years 11 months ago #23579 by skepticals
Yes, save it:
[code:1]write memory[/code:1]
What is your topology? You have 1 router and two PCs? Are they connetect to a switch or are you directly plugged into the router's interfaces?
18 years 11 months ago #23588 by skepticals
I setup a quick test in my lab:
PC1: 192.168.1.100 255.255.255.0
Default Gateway 192.168.1.254
PC2: 192.168.2.100
Default Gateway 192.168.2.254
Here is how I connected them:
PC1==Crossover Cable==E0/0
PC2==Crossover Cable==E0/1
One machine is running XP and the other is running Windows 2000
Current configuration : 793 bytes
version 12.2
hostname Cisco
logging queue-limit 100
ip subnet-zero
ip audit notify log
ip audit po max-events 100
no voice hpi capture buffer
no voice hpi capture destination
mta receive maximum-recipients 0
half-duplex
half-duplex
ip http server
no ip http secure-server
ip classless
call rsvp-sync
mgcp profile default
dial-peer cor custom
line con 0
line aux 0
line vty 0 4
end
I was able to ping all interfaces and accross to the other PC from either direction.
I even removed the routes and it worked because the networks are directly connected:
no ip route 192.168.1.0 255.255.255.0 Ethernet0/0
no ip route 192.168.2.0 255.255.255.0 Ethernet0/1
