Help help help cisco routing
18 years 10 months ago #23544 by vitamin
I have done that still does not work.... however... I can ping hosts from the router no problems at all.
18 years 10 months ago #23546 by skepticals
No, I think you need to remove 'no ip routing'.
I think if you have 'no ip routing' in your config that it will not route, it will only act as an IP host.
Have you tried removing that line from the config?
18 years 10 months ago #23547 by vitamin
makes no difference..... still I can ping both interfaces on the router just not whats on the other side of them....
18 years 10 months ago #23548 by skepticals
You can ping both interfaces from one side of the router?
What computers are you trying to ping? Are they XP with a firewall enabled? Because that can stop the ping...
18 years 10 months ago #23549 by vitamin
I can ping both interfaces of the router from clients either side of the router I just can ping between the clients them selves.
And yes all firewall's etc are disabled.
18 years 10 months ago #23550 by Dove
can you paste the Running config now...as well as can you check the Default gateway IP address in both the PCs.
Dove
