help me how to subnet class A, B & C
- ashok_nitc
- Junior Member
18 years 4 hours ago #20865
by ashok_nitc
Replied by ashok_nitc on topic Re: help me how to subnet class A, B & C
well durk21 sorry then, you understood the point from the begining itself then...then why you did not tell at that time itself.
is there any other difference between VLSM and classful subnetting??
18 years 4 hours ago #20867
by durk21
Replied by durk21 on topic Re: help me how to subnet class A, B & C
i stated that it didn't work with vlsm from nearly the beginning and multiple times in my postings
- ashok_nitc
- Junior Member
18 years 3 hours ago #20870
by ashok_nitc
well durk21!!
thanks, atleast i got a new name for my concept!!
18 years 3 hours ago #20873
by durk21
AND....................that is?
- ashok_nitc
- Junior Member
18 years 3 hours ago #20876
by ashok_nitc
VLSM
18 years 3 hours ago #20877
by Dove
Dove
Replied by Dove on topic Re: help me how to subnet class A, B & C
Hi Ashok
VLSM is nothing but Variable length Subnet Mask. Which is used to preserv the IP wastage.... say If you need only 10 usable IP for your network...but if you use the IP 192.168.1.0/24 it gives 255 IPs, so the remaining 245 IP are unused...right..?
If you split the IP block with appropriate subnet mask (VLSM / CIDR) you can breakup the subnet blocks.
For the above example...you may use the Subnet mask as 255.255.255.240...it will give you 14 usable host IPs. So here you are wasting only 4 IPs...compare to using the default subnet mask...
Hope it may give some hint for you abt VLSM
Dove
Time to create page: 0.240 seconds
