- Thank you received: 1
help me how to subnet class A, B & C
One more question to you...
what you think : for a class B address can i use 255.255.255.240 as a subnet musk?
according to your previous post answer is no. but i guess you have the actual picture of the network.
To answer this NO you can not use it for a CLASS B
BUT CLASS C NO PROBLEM!
This is what my teachers have show me. It should also be in any good CCNA CISCO textbook.
I belive some where you missing out the concept......
you can use the subnet mask 255.255.255.240 for Class A IP address...for Example say
IP: 10.1.1.1 / 28 (255.255.255.240)
The IP setting will give you
Network Address: 10.1.1.0
Broadcast Address: 10.1.1.15
First Host IP : 10.1.1.1
Last Host IP : 10.1.1.14
So, It says any subnet mask can be used with any IP class.
Dove
believe some where you missing out the concept......
Because i wasn't referring to the actual use of VLSM I was merely referring to the basics of subnetting as per the original topic.
Hi Durk21
Hehe, this was what i was just thinking on my way to work. The only explination was that we are mixing the standard Classfull subnets 255.0.0.0/255.255.0.0 & 255.255.255.0 with VLSM.
- ashok_nitc
- Junior Member
thanks man!! however can you discuss something about VLSM?
I don't have idea about VLSM!! from the discussion above it seems that whatever i was trying(Dove also) to say is the VLSM?(example given by Dove is example of VLSM??)
and whatever durk21 is telling is the actual picture of classful addressing?
Smurf,
Yes I am Using the CLASSFUL Subnetting technique in my previous posts. I AM NOT NOT subnetting using VLSM. If you want to subnet using VLSM look at Doves example.
I was posting on the original topic.
