Re-direction problems in IPCOP
18 years 8 months ago #15892 by facer
Sorry da_light but now i am trying to use the advanced proxy ad on and you fix no longer works.
I have tired all the i can think of but cannot get it to work.
Even when i try and add the code in to the squid.conf file itself, and not change anything on the gui it dosn't work.
When i restart squid via the command line i get this error
[code:1]2006/07/28 15:06:42| parseConfigFile: line 89 unrecognized: 'always__direct allo w HOST_IP'
2006/07/28 15:06:42| Creating Swap Directories
Any ideas?
18 years 8 months ago #15894 by DaLight
I haven't actually installed the Advanced Proxy addon, although I think it's a really nice feature. However, looking through the documentation, it appears that any custom changes to the proxy settings need to be made to the following file:
[code:1]/var/ipcop/proxy/advanced/acls/include.acl[/code:1]
Therefore remove the code from the /var/ipcop/proxy/acl file, add it to the above file and then restart the Proxy Service from the GUI.
18 years 8 months ago #15895 by facer
Yup that worked a treat!
Probley could have found that myself by looking through the documentation but i don't realy know what i'm looking for!
Thanks very much mate 8)
