Re-direction problems in IPCOP
18 years 8 months ago #15680
by facer
Replied by facer on topic Re: Re-direction problems in IPCOP
Sorry i think we got our wires crossed a bit (my fault for not properly descirbing the problem!)
By the banned page i mean the one i have a screen shot of in my last post.
Yes i have the ipcop ip adrress set in internet explorer as my proxy.
18 years 8 months ago #15688
by DaLight
Replied by DaLight on topic Re: Re-direction problems in IPCOP
Just had an idea. Could you post your /var/ipcop/urlfilter/squidGuard.conf and /var/ipcop/urlfilter/settings files?
18 years 8 months ago #15691
by facer
logdir /var/log/squidGuard
dbhome /var/ipcop/urlfilter/blacklists
dest ads {
domainlist ads/domains
urllist ads/urls
dest aggressive {
domainlist aggressive/domains
urllist aggressive/urls
dest audio-video {
domainlist audio-video/domains
urllist audio-video/urls
dest drugs {
domainlist drugs/domains
urllist drugs/urls
"squidGuard.conf" 81L, 1500C
FILTER_GAMBLING=on
ENABLE_CUSTOM_EXPRESSIONS=off
BLOCK_ARCHIVES=off
FILTER_AGGRESSIVE=on
ENABLE_EMPTY_ADS=off
ENABLE_AUTOUPDATE=off
ENABLE_GLOBAL_WHITELIST=off
ENABLE_EXPR_LISTS=off
FILTER_DRUGS=on
BLOCK_IP_ADDR=off
ENABLE_JPEG=off
UNFILTERED_CLIENTS=
BANNED_CLIENTS=
MSG_TEXT_3=
ENABLE_CUSTOM_WHITELIST=off
FILTER_MAIL=on
ENABLE_SAFESEARCH=off
FILTER_PROXY=on
FILTER_WAREZ=on
FILTER_HACKING=on
ENABLE_REWRITE=off
SHOW_URL=off
REDIRECT_PAGE=
"settings" 41L, 755C
dest ads {
urllist ads/urls
dest aggressive {
dest audio-video {
dest drugs {
urllist drugs/urls
FILTER_GAMBLING=on
BLOCK_ARCHIVES=off
FILTER_DRUGS=on
BLOCK_IP_ADDR=off
ENABLE_JPEG=off
UNFILTERED_CLIENTS=
BANNED_CLIENTS=
MSG_TEXT_3=
FILTER_MAIL=on
FILTER_PROXY=on
FILTER_WAREZ=on
FILTER_HACKING=on
ENABLE_REWRITE=off
SHOW_URL=off
REDIRECT_PAGE=
18 years 8 months ago #15692
by DaLight
Could you also post your /var/ipcop/proxy/squid.conf file?
18 years 8 months ago #15704
by facer
Yup
[code:1]shutdown_lifetime 5 seconds
icp_port 0
http_port 191.168.0.3:3128
acl QUERY urlpath_regex cgi-bin \?
no_cache deny QUERY
cache_effective_user squid
cache_effective_group squid
pid_filename /var/run/squid.pid
cache_access_log /var/log/squid/access.log
cache_log /var/log/squid/cache.log
cache_store_log none
log_mime_hdrs off
forwarded_for off
# Do not modify '/var/ipcop/proxy/squid.conf' directly since any changes^M
# you make will be overwritten whenever you resave proxy settings using the^M
# web interface! Instead, modify the file '/var/ipcop/proxy/acl' and then^M
"squid.conf" 91L, 2591C
icp_port 0
no_cache deny QUERY
log_mime_hdrs off
forwarded_for off
18 years 8 months ago #15707
by DaLight
The squid.conf you posted has a few missing entries:
1. There is no mention of your external proxy.
2. The SquidGuard redirector (used by Urlfilter) is not enabled.
Have you changed your Proxy settings via the Web GUI?
