Re-direction problems in IPCOP
18 years 8 months ago #15612
by facer
Re-direction problems in IPCOP was created by facer
I am trying to set up the url filter ad on for IP cop.
It seems to work very well the only problem i am having is that when you try and access a blocked page, ip cop sends the requested for the banned site page out to the external proxy, and seen as it is a local (192.) address the proxy denies acces to it. There is a link on the denided page from the external proxy pointing to the 192 address, and if you click that then the url filter banned page is dispalyed as the browser is set up not to send requests for local address out to the proxy.
Is there any way this setting in the url filter can be changed so it dosn't send the request to the external proxy?
Any help would be greatly appriciated.
18 years 8 months ago #15613
by DaLight
Replied by DaLight on topic Re: Re-direction problems in IPCOP
Welcome to firewall.cx, facer.
I'm don't quite understand your question. Can you answer the following:
1. Do you have another proxy server on your network in addition to your IPCOP (Squid)?
2. Is your Squid running in Transparent mode on GREEN?
3. Have you entered any value in the "Redirect to this URL" field on the URLFilter settings page?
4. Do you have an upstream proxy specified in the Webproxy settings page?
18 years 8 months ago #15614
by facer
Replied by facer on topic Re: Re-direction problems in IPCOP
Thanks da light
No, i am just pointing the browser straight to IPCOP
Do you mean on the IPCOP? If so, no. But i have tried it on transparent but it don't seem to make a difference
No, i am trying to use the standard page in URl filter.
Yes, as that is how i connect to the internet (that's the external proxy i refer to)
18 years 8 months ago #15621
by DaLight
Any chance of a screen shot of the "Access Denied" warning page from the proxy.
18 years 8 months ago #15626
by facer
18 years 8 months ago #15628
by DaLight
Relying on the "Bypass proxy server for local addresses" option is probably not a good idea.
Best thing is to set Squid to TRANSPARENT and then block all IP access in iptables.
This way, all HTTP and FTP traffic will be forced to go through the proxy server and no-one will be able to go out on any ports apart from 21, 80, 443 (and others specified in your /var/ipcop/proxy/squid.conf file)
