Re-direction problems in IPCOP
18 years 8 months ago #15811 by facer
I had a idea looking at that.
I tired changing this line in the spuidGuard.conf
[code:1] redirect http://191.168.0.3:81/redirect.cgi [/code:1]
to
[code:1] redirect http://localhost:81/redirect.cgi [/code:1]
But it didn't make any difference what so ever. Still displays the IP address in the external proxy access denied page.
18 years 8 months ago #15816 by DaLight
Add the following code:
[code:1]acl HOST_IP dst 191.168.0.3
always_direct allow HOST_IP
just before the line containing:
[code:1]never_direct allow all
in your /var/ipcop/proxy/acl file, then restart the Proxy Service from the GUI (not using /usr/local/bin/restartsquid)
18 years 8 months ago #15832 by facer
This is my acl file
[code:1] acl
acl IPCop_http port 81
acl IPCop_https port 445
acl IPCop_ips dst __GREEN_IP__ __BLUE_IP__
acl IPCop_networks src __GREEN_NET__ __BLUE_NET__
acl CONNECT method CONNECT
##Access to squid:
#local machine, no restriction
http_access allow localhost
#GUI admin if local machine connects
http_access allow IPCop_ips IPCop_networks IPCop_http
http_access allow CONNECT IPCop_ips IPCop_networks IPCop_https
#Deny not web services
http_access deny !Safe_ports
http_access deny CONNECT !SSL_ports
#Finally allow IPCop_networks clients
http_access allow IPCop_networks
http_access deny all
ttp_access deny all
I can not find the line you are refering too. Is it just me bein blind?
18 years 8 months ago #15833 by DaLight
Sorry, my mistake!
Add the code after the last line in your /var/ipcop/proxy/acl file:
18 years 8 months ago #15835 by facer
That's worked!! :D :D :D
Thank you very much for your help Da light :D was beginning to give up on IPcop!
Your a absalute star! 8)
Thanks again :D
18 years 8 months ago #15839 by DaLight
Phew! That was a marathon. Glad it's working OK, facer.
The added code simply ensures that web requests which are explicitly directed at your IPCOP do not get forwarded to the external proxy server.
