Routing & ACL question
14 years 1 month ago #36234 by Nevins
I was just wondering what the "MOST" recent running config was. I was not sure if the first one was your current running config or not. So what we are looking at here is the networks which are the ones you said worked correctly, correct?
Edit: can you post the other config and label the commands you used to make the changes? Basically I want to put the config that works side-by-side with the one that doesn't so I can determine why it doesn't.
Currently it looks as if it should work as discribed and you might have fat fingered something and simply got it right when you made changes. I don't know to be honest I'm simply not seeing it.
Useful Threads
14 years 1 month ago #36237 by apit
Replied by apit on topic Re: Routing & ACL question
Sorry, missed that one!
Can you give the ACL's a try and let us know of the results ?
Chris,
I think we discuss the ACL in other thread.. www.firewall.cx/ftopict-8099.html
Nevins,
I will post the configuration...Need to reconfigure back the router base on the above situation.
Currently i'have change the configuration..
14 years 1 month ago #36242 by apit
Router 1 Config [/b]"]
router-1#sh run
Building configuration...
Current configuration : 2902 bytes
! Last configuration change at 09:08:17 UTC Wed Feb 9 2011 by admin
! NVRAM config last updated at 08:48:34 UTC Mon Feb 7 2011 by admin
version 12.x
service timestamps log datetime localtime
service password-encryption
hostname HQ
boot-start-marker
boot-end-marker
logging count
logging buffered 4096
logging monitor informational
enable secret 5 xxxxxxxxxxxxxxxx
aaa new-model
aaa session-id common
dot11 syslog
ip cef
ip domain name www.test.com
multilink bundle-name authenticated
voice-card 0
no dspfarm
username admin secret 5 xxxxxxxxxxxxxxxx/
archive
log config
hidekeys
ip ssh version x
interface GigabitEthernet0/0
description ####### Network 1 ########
ip address 172.16.10.1 255.255.255.0
duplex full
speed auto
media-type rj45
interface GigabitEthernet0/1
description ##### Network 2 ######
ip address 192.168.0.1 255.255.255.0
duplex auto
speed auto
media-type rj45
interface FastEthernet0/0/0
description ######## MAN Connection ########
ip address 10.1.1.1 255.255.255.252
duplex full
speed auto
interface Serial0/1/0
no ip address
shutdown
clock rate 2000000
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 172.16.1.1
ip route 172.16.20.0 255.255.255.0 172.16.10.1
ip route 172.16.21.0 255.255.255.0 172.16.10.1
ip route 172.16.22.0 255.255.255.0 172.16.10.1
ip route 172.16.30.0 255.255.255.0 10.1.1.2
ip route 172.16.31.0 255.255.255.0 10.1.1.2
ip route 172.16.32.0 255.255.255.0 10.1.1.2
no ip http server
no ip http secure-server
access-list 1 deny 192.168.0.0 0.0.0.255 log
access-list 1 permit any log
access-list 2 permit 192.168.0.0 0.0.0.255 log
access-list 2 deny any log
control-plane
line con 0
password 7 051F0B012ABABABABA
line aux 0
line vty 0 4
password 7 08354140QWERTYU
transport input ssh
scheduler allocate 20000 1000
ntp clock-period 17179798
ntp server time.sirim.my
end
router-1#
Router 2 Config [/b]"]
router-2#sh run
Current configuration : 2804 bytes
version 12.x
hostname branch
boot-start-marker
boot-end-marker
logging count
logging buffered 16777216
enable secret 5 $1$lCSg$ptxxryynki666
aaa new-model
dot11 syslog
ip cef
voice-card 0
no dspfarm
voice service voip
allow-connections h323 to h323
username admin secret 5 $1$CBgg$z2Vekdcrftyhujuj
archive
log config
hidekeys
ip address 172.16.10.2 255.255.255.0
duplex auto
speed auto
media-type rj45
ip address 192.168.0.2 255.255.255.0
duplex auto
speed auto
media-type rj45
ip address 10.1.1.2 255.255.255.252
duplex full
speed auto
no ip address
shutdown
clock rate 2000000
ip route 0.0.0.0 0.0.0.0 10.1.1.1
no ip http server
control-plane
line con 0
password 7 00101E080frfrgtgt
line aux 0
line vty 0 4
password 7 14031F0xxxxxxeeeee
transport input ssh
end
router-2#
14 years 1 month ago #36243 by apit
Test PING From Router 1
router-1#sh run int gi 0/1
Current configuration : 152 bytes
duplex auto
speed auto
media-type rj45
end
##### PING From Router 1 To Interface Gi 0/1 At Router 1 #########
router-1#ping 192.168.0.1
Sending 5, 100-byte ICMP Echos to 192.168.0.1, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/1/4 ms
##### PING From Router 1 To Interface Gi 0/1 At Router 2 #########
router-1#ping 192.168.0.2
Sending 5, 100-byte ICMP Echos to 192.168.0.2, timeout is 2 seconds:
Success rate is 0 percent (0/5)
router-1#
Test PING From Router 2
duplex auto
speed auto
media-type rj45
end
##### PING From Router 2 To Interface Gi 0/1 At Router 2 #########
router-2#ping 192.168.0.2
##### PING From Router 2 To Interface Gi 0/1 At Router 1 #########
router-2#ping 192.168.0.1
router-2#
14 years 1 month ago #36244 by Nevins
Lets probe deeper.
File Attachment:
Please provide ping information for router 1 fa0/0 to router 2 fa0/0.
Useful Threads
14 years 1 month ago #36249 by apit
Lets probe deeper.
this discussion become more interesting... colorful thread... :D
attach here with the diagram for this situation
File Attachment:
Uploaded with ImageShack.us
so this is the fa0/0 and Ga 0/0 PING result from both router :
duplex auto
speed auto
media-type rj45
end
##### PING From Router 1 To Interface Fa 0/0/0 At Router 1 #########
router-1#ping 10.1.1.1
Sending 5, 100-byte ICMP Echos to 10.1.1.1, timeout is 2 seconds:
##### PING From Router 1 To Interface Fa 0/0/0 At Router 2 #########
router-1#ping 10.1.1.2
Sending 5, 100-byte ICMP Echos to 10.1.1.2, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/2/4 ms
##### PING From Router 1 To Interface Gi 0/0 At Router 1 #########
router-1#ping 172.16.10.1
Sending 5, 100-byte ICMP Echos to 172.16.10.1, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/1/1 ms
##### PING From Router 1 To Interface Gi 0/0 At Router 2 #########
router-1#ping 172.16.10.2
Sending 5, 100-byte ICMP Echos to 172.16.10.2, timeout is 2 seconds:
duplex auto
speed auto
media-type rj45
end
##### PING From Router 2 To Interface Fa 0/0/0 At Router 2 #########
router-2#ping 10.1.1.2
##### PING From Router 2 To Interface Fa 0/0/0 At Router 1 #########
router-2#ping 10.1.1.1
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/3/4 ms
##### PING From Router 2 To Interface Gi 0/0 At Router 2 #########
router-2#ping 172.16.10.2
##### PING From Router 2 To Interface Gi 0/0 At Router 1 #########
router-2#ping 172.16.10.1
Time to create page: 0.233 seconds
