Routing & ACL question
15 years 7 months ago #36270 by apit
Replied by apit on topic Re: Routing & ACL question
Now lets take this logic and apply it to our current situation. If you a host pc on the router 1 attached network 196.186.0.0/24 with an ip address of 196.186.0.5 and you want to contact(ping) the address 196.136.0.6 on the router 2 attached network of 196.186.0.0/24 what will happen when host 1 tries to transmit a ping to 196.186.0.5/24?
Do you mean a host at network 2 connected to router 1 via Gi 0/1 using ip 192.168.0.5 try to ping to a host at network 2 connected to router 2 via Gi 0/1 using ip 192.168.0.6 ?
File Attachment:
Uploaded with ImageShack.us
If refer to the above diagram, host 192.168.0.5 will :
1- Compare source ip(192.168.0.5) & subnetmask(255.255.255.0) with destination ip(192.168.0.6) & subnetmask(255.255.255.0). In that case, source & destination is the same.
2- Check destination Mac address (192.168.0.6) exist or not in router 1. Try issue "sh ip arp". No Mac address (192.168.0.6) found.
3- Send ARP request for 192.168.0.6 (from router 1 to router 2)
4- create frame with source 7 destination host MAC.
5- Ping return success
15 years 7 months ago #36272 by Nevins
Your partially correct. Lets work though using our logic table.
The statment:
Compare source ip(192.168.0.5) & subnetmask(255.255.255.0) with destination ip(192.168.0.6) & subnetmask(255.255.255.0). In that case, source & destination is the SAME.
Is roughly equivalent to the logic statement :
IF HOST IP && HOST SUBNET MASK = DESTINATION IP && DESTINATION SUBNETMASK which in the current situation equates to the TRUE leg of the logic.
File Attachment:
So the next thing we must look at is if the destination mac address would exist in host 192.168.0.5's mac address table. Would it exist in the mac address table? Does host 192.168.0.5 have 192.168.0.6's mac address in it's table?
Useful Threads
15 years 7 months ago #36303 by apit
oh i see...we have to check the destination MAC 192.168.0.6 in host 192.168.0.5 MAC address table...i though that we have to check the destination MAC in router 1 by issue command "show ip arp"...
To check MAC address table in host 192.168.0.5, just issue command "arp -a"...so the result no MAC address for host 192.168.0.6 found in MAC Address table host 192.168.0.5
15 years 7 months ago #36310 by Nevins
File Attachment:
Okay so the computer puts out an arp request to everyone on the Lan segment:
Essentially the arp request is asking does anyone have the Mac address for 192.168.0.6 ?
So does anyone reply with the mac address for 192.168.0.6?
Useful Threads
15 years 7 months ago #36314 by apit
Anyone in this scenario is a switch or router?
Both switch & router 1 do not reply the 192.168.0.6 MAc Address.
15 years 7 months ago #36315 by Nevins
There is only one rule in replying to arp packets. The rule is "if you are the destination reply".
So in this example would 196.168.0.6 be able to reply to the arp request?
File Attachment:
Useful Threads
Time to create page: 0.098 seconds
