Routing & ACL question
Refer to the attached diagram...
Uploaded with ImageShack.us
Below are the configuration for router 1 (HQ) and router 2 (branch)..
Router 1
static route
0.0.0.0 0.0.0.0 172.16.1.1
172.16.20.0 255.255.255.0 172.16.10.1
172.16.21.0 255.255.255.0 172.16.10.1
172.16.22.0 255.255.255.0 172.16.10.1
172.16.30.0 255.255.255.0 10.1.1.2
172.16.31.0 255.255.255.0 10.1.1.2
172.16.32.0 255.255.255.0 10.1.1.2
interface GigabitEthernet0/0
description *** Open LAN ***
ip address 172.16.10.1 255.255.255.252
ip access-group 1 in
duplex full
speed auto
media-type rj45
interface GigabitEthernet0/1
description ********* Close LAN **************
ip address 192.168.0.126 255.255.255.128
ip access-group 2 in
duplex auto
speed auto
media-type rj45
interface FastEthernet0/0/0
description *** ISP MAN Connection ***
ip address 10.1.1.1 255.255.255.252
duplex full
speed auto
ACL
Gi 0/0
access-list 1 deny 192.168.0.0 0.0.0.255
access-list 1 permit any
Gi 0/1
access-list 2 permit 192.168.0.0 0.0.0.255
access-list 2 deny any
Router 2
0.0.0.0 0.0.0.0 10.1.1.1
ip address 172.16.10.5 255.255.255.252
duplex full
speed auto
media-type rj45
description ******* Close LAN **********
ip address 192.168.0.254 255.255.255.128
duplex auto
speed auto
media-type rj45
ip address 10.1.1.2 255.255.255.252
duplex full
speed auto
ACL
Gi 0/0
Gi 0/1
Questions For Routing :
1- Can we use the same ip & subnet for Gi 0/1... Example for router 1 Gi 0/1 using ip 192.168.0.1/24 and for router 2 Gi 0/1 using ip 192.168.0.2/24? I'have try it but fail to ping each other..
2- If questions 1 possible, do we need to add routingat both router? Let say routing "ip route 192.168.0.0 255.255.255.0 10.1.1.2" at router 1 and " ip route 192.168.0.0 255.255.255.0 10.1.1.1" at router 2?
Questions For ACL :
I want to make network 1 & network 2 separated each other... User that using 172.16.x.y cannot access / ping to user that using ip 192.168.0.x /24....Network 1 can access to the internet but network 2 just access local application which is private to network 1.
I already configured my both router with above ACL but user at network 1 at branch still can ping to interface Gi 0/1 at both router 1 and router 2.
Is it because of ACL rules? How to correct it?
You asked:
I assume you mean can you use the private address range 192.168.x.x on two networks and have the communicate. The answer to that is yes with strings and conditions attached. 192.168.x.x is a special address range along with 10.x.x.x and 172.16.x.x-172.31.x.x which was intended to be used with NAT(network address translation). If NAT was not properly configured your going to have some problems.
You also asked:
2- If questions 1 possible, do we need to add routing at both routers? Let say routing "ip route 192.168.0.0 255.255.255.0 10.1.1.2" at router 1 and " ip route 192.168.0.0 255.255.255.0 10.1.1.1" at router 2?
No. You are essentially never going to use the IP route command with a private address. They are Non-routable addresses.
Useful Threads
yup..both router(router 1 & router 2) are in the private network...So i'm using privte IP for Gi0/0, Gi 0/1 and Fa 0/0/0....I've tried using 192.168.0.1/24 at router 1 Gi0/1 and 192.168.0.2/24 at router 2 but failed during the PING test...
After change it to the different subnet, PING test success (I change the router 1 Gi0/1 to 192.168.0.1/25 and router 2 Gi0/1 to 192.168.0.129/25).... Why is it happen?
The answer may be starting me in the face at the moment, but it's half-time for the superbowl and I simply don't see it at the moment. Anyways post the current running configs for both router 1 and 2 and we'll try to work from there.
Useful Threads
Router 1
duplex full
speed auto
media-type rj45
duplex auto
speed auto
media-type rj45
duplex full
speed auto
ip route 0.0.0.0 0.0.0.0 172.16.1.1
ip route 172.16.20.0 255.255.255.0 172.16.10.1
ip route 172.16.21.0 255.255.255.0 172.16.10.1
ip route 172.16.22.0 255.255.255.0 172.16.10.1
ip route 172.16.30.0 255.255.255.0 10.1.1.2
ip route 172.16.31.0 255.255.255.0 10.1.1.2
ip route 172.16.32.0 255.255.255.0 10.1.1.2
Router 2
duplex full
speed auto
media-type rj45
duplex auto
speed auto
media-type rj45
duplex full
speed auto
ip route 0.0.0.0 0.0.0.0 10.1.1.1
Can you give the ACL's a try and let us know of the results ?
