NIC problem
20 years 2 weeks ago #7958
by aminos
Replied by aminos on topic Re: NIC problem
Well
Thanks guys for ur responses i think i would replace it by a well
Known one it's better
- LooseCannon
- Junior Member
20 years 2 weeks ago #7960
by LooseCannon
Replied by LooseCannon on topic Re: NIC problem
Well once I get off work I will have a look around and see what I can dig up. It was pretty easy to fix the problem in Gentoo so it shouldn't be too hard in Mandrake. Have you done a search on Mandrake's forums?
20 years 2 weeks ago #7961
by nske
Replied by nske on topic Re: NIC problem
hey don't surrender so easily aminos, chances are that it is supported! The result of "lspci |grep Ethernet" should return the NIC manufacturer and chip. Then you can proceed in compiling a kernel with that driver or compiling just the driver module. As mentioned, just download the kernel source, extract it, cd to it's dir, then issue "make menuconfig", browse down to the "Device Drivers", "Networking Support", "Ethernet (10 or 100Mbit)" section and you should get a list with all officially supported NICs. You can get more detailed info on each one (such as the complete supported model list) by issuing a "?" character for each item of the menu. If you need help with the details you can always ask here, but there's not much to it once you understand how it works. Check
Kernel Rebuild Guide
first.
20 years 2 weeks ago #7964
by aminos
Thanks nske,
well actually, i found a last in the NIC box that my card name is TAMARAK so i made # make xconfig in order to check if it's supported
unfortunally it's not listed in the kernel, so i tried to find a compatible
NIC card driver,anyways thanks for your help it's great to hear from you
20 years 2 weeks ago #7966
by sahirh
Replied by sahirh on topic Re: NIC problem
If its an Intel chipset, it will definetely feature somewhere in the kernel config. I'm surprised its not already loaded it. Have you tried a distro with good hardware support ? Try Ubuntu or the Knoppix LiveCD and see if they detect it, I'm sure they will.
20 years 2 weeks ago #7972
by aminos
Sorry,
I miselead you guys, actually when i make
# lspci | grep Ethernet
whai I get is :
MYSON technology inc : Unknown device 0803
so i don't think it's intel compatible
[/code]
whai I get is :
[/code]
