HELP with NTFS mount
20 years 7 months ago #4818
by sahirh
Replied by sahirh on topic Re: HELP with NTFS mount
Or you can recompile your kernel after patching it.. good luck trying to stuff a 2.6 series kernel into RH9...
Seriously.. RH9 is outdated, not well supported.. etc..
just upgrade, get yourself SuSE 9.1, you'll get the spanking 2.6 series kernel (which you cannot live without after you see how much snappier than 2.4 it is).. and you'll get all the latest apps etc..
I really suggest if you're new to linux you get the new knoppix 3.6, and do the hdd-install.. its very very easy to use, and damn powerful...
this post was typed from Knoppix 3.6 running Firefox 0.9.3 in KDE 3.2.3
*bliss*
*bliss*
Time to create page: 0.164 seconds
