HELP with NTFS mount
20 years 7 months ago #4799
by Nitix
Nitish R
Systems Engineer
HELP with NTFS mount was created by Nitix
i use a dual boot on my machine..
how do i mount my NTFS volume on RH 9.0 and access my files from there?
Nitish R
Systems Engineer
20 years 7 months ago #4801
by drizzle
Replied by drizzle on topic Re: HELP with NTFS mount
Thorpe is right! They should have pre-built RPM's for RH 9. Just make a note of your kernel version before you download. The only problem with them is they are Read-Only for RedHat and Fedora. Other distros have read+write NTFS drivers why rebuild your box just so you can write to NTFS partitions...
D
D
20 years 7 months ago #4807
by sahirh
Replied by sahirh on topic Re: HELP with NTFS mount
Otherwise you can try captive ntfs
www.jankratochvil.net/project/captive/
RH9 is really a pain, I suggest you try Debian or SuSE..
Or knoppix hard-disk installed if you are new to Linux
www.knoppix.net
www.knoppix.net
20 years 7 months ago #4810
by Nitix
Nitish R
Systems Engineer
Replied by Nitix on topic Re: HELP with NTFS mount
thnx guys ...
i installed the patch and am able to acces the NTFS partitions...
great its just a read only !!!
anyfing with WRE !!
rgds
Nitish
anyfing with WRE !!
rgds
Nitish
Nitish R
Systems Engineer
