HELP !!! Can't Connect to wireless network
16 years 10 months ago #26428 by Alans
Did you tried to connect your laptop to the router using a cable?
Try this and check for products manual, see if there is a defualt IP (usually it's 192.168.0.1 or 192.168.1.1) then set your IP to that range and try to open http://thataddress...
always Face your Fears...
16 years 9 months ago #26436 by bigdp
Replied by bigdp on topic Wireless madness
hi this is the result on my wired connection after the ping command.
thanks for all your help
C:\>ping 192.168.0.1
Pinging 192.168.0.1 with 32 bytes of data:
Reply from 192.168.0.1: bytes=32 time<1ms TTL=255
Ping statistics for 192.168.0.1:
Minimum = 0ms, Maximum = 0ms, Average = 0ms
16 years 9 months ago #26437 by S0lo
It's alive.
Just to clear my doubt, Is your ADSL (internet connection wire) connected to your PC or to your netgear ?
16 years 7 months ago #27304 by Lav_plsb
You are getting correct IP address, able to ping the Default Gateway and able to go online with wired computers
But, unable to pullup the Router Setup page. You need to disable the firewall and do IE settings (i.e Delete cookies, browsing history) or try on different browser
or click start>Run type in "http://192.168.0.1"
