HELP !!! Can't Connect to wireless network
16 years 10 months ago #26413 by bigdp
hi folks
i am having a problem connecting to my wireless network
i have a pc that i installed my netgear wireless router on. my pc has no wireless on it so i connect to the net on this by using the wire.
i bought a laptop and tried to set up wireless on my router so that i can go on net with my laptop wirelessly (it won't work)
i took the laptop to friends house and browsed for his wireless network, found it and connected to the net no problem.
with my network it says i am connected but when i try and browse i cannot. it says limited or no connectivity.
surely it can't be laptop settings as friends network is easy to browse the net.
cheers.
any help will be appreciated
16 years 10 months ago #26415 by S0lo
Have you browsed your Netgear web interface configuration? What shows in the configs?
16 years 10 months ago #26418 by bigdp
hi
i can,t browse my router interface. everytime i try it doesn't work, unless i'm doing something wrong and stupid.
16 years 10 months ago #26420 by TheBishop
Bring up a Command Prompt box on your wire-connected PC (start -> run -> cmd). Type in ipconfig /all and find out what the default gateway address is. Now open your web browser and try to access http://<that address>. That will probably give you the configuration page of your Netgear
16 years 10 months ago #26424 by bigdp
hi bishop
i did what you told me and the default gateway was 192.168.0.1
i typed http://192.168.0.1 into the address bar on my wired pc and i got couldn't find page.
this is the result when i type in ipconfig /all
Microsoft Windows XP [Version 5.1.2600]
(C) Copyright 1985-2001 Microsoft Corp.
C:\Documents and Settings\David Parris>cd..
C:\Documents and Settings>cd..
C:\>ipconfig /all
Windows IP Configuration
Host Name . . . . . . . . . . . . : DAVID
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Unknown
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
Ethernet adapter Local Area Connection:
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : Realtek RTL8029(AS)-based Ethernet A
dapter (Generic)
Physical Address. . . . . . . . . : 00-20-18-3C-E7-63
Dhcp Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
IP Address. . . . . . . . . . . . : 192.168.0.3
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Default Gateway . . . . . . . . . : 192.168.0.1
DHCP Server . . . . . . . . . . . : 192.168.0.1
DNS Servers . . . . . . . . . . . : 192.168.0.1
Lease Obtained. . . . . . . . . . : 03 June 2008 15:37:07
Lease Expires . . . . . . . . . . : 04 June 2008 15:37:07
PPP adapter The Internet (2):
Description . . . . . . . . . . . : WAN (PPP/SLIP) Interface
Physical Address. . . . . . . . . : 00-53-45-00-00-00
Dhcp Enabled. . . . . . . . . . . : No
IP Address. . . . . . . . . . . . : 172.141.218.149
Subnet Mask . . . . . . . . . . . : 255.255.255.255
DNS Servers . . . . . . . . . . . : 205.188.146.145
NetBIOS over Tcpip. . . . . . . . : Disabled
C:\>
thanks for any help you can give me
16 years 10 months ago #26427 by S0lo
Strange, I'm also not sure why it shows a PPP WAN adapter here. I'm beginning to have other doubts. On the same (start -> run -> cmd) type:
ping 192.168.0.1
What does it show you ?
