D-Link -access point & cisco switch problem
17 years 2 months ago #24606
Replied by S0lo on topic Re: D-Link -access point & cisco switch problem
So you were saying when you connect a PC direct to the access point in building 3, there was no problems. Am I correct ?
Did you try applying static IPs on the those PC on Buliding 3 ? If it works with static IPs then you'll be sure that the problem is related to DHCP not anything else.
17 years 2 months ago #24642
by ahmedrami
Replied by ahmedrami on topic Re: D-Link -access point & cisco switch problem
Unfortunately, the problem still exists, even after applying the static ip address.
17 years 2 months ago #24643
No DHCP issue, Then, If it works correctly without the switch at building 3. My doubts are headed to that switch. I would do the following:
1. Make sure the PCs at building 3 can ping each other. If they can't, it would seam that you have a problem with the switch.
2. You might need a crossover UTP cable between the AP and switch in building 3.
3. Try another port in the switch to connect to the AP.
17 years 2 months ago #24644
by ahmedrami
Thank you (S0lo)for interaction, we have solved the problem,by change in the mode of the access point from Repeater to Clint.
16 years 10 months ago #26047
by talk2sp
BORN TO BE GREAT
c0de - 3
Replied by talk2sp on topic interactive post... (interview technique)
Hi Ahmed i love ur post and how u came about ur solution on the equipment in building 3. a colleague and i will be using ur diagram to interview someone...
sounds funny right but believe me we will interview some up coming net admin.
nice post once again.
BORN TO BE GREAT
c0de - 3
