- Thank you received: 10
wireless problem - cannot grab ip
19 years 5 months ago #10733
by Arani
Replied by Arani on topic listen to the berzerker
i would actually go by bezerker's advice on the ap's. its pretty obvious that the switch should be acting as a dhcp, unless you would assign ip address yourself to the hosts, and make a static table for connectivity
19 years 5 months ago #10773
by jhun
Replied by jhun on topic Re: wireless problem - cannot grab ip
well now that cleared up something...
the problem, as have been pointed out would be in the building 1's AP. base on your previous posts it seems that it is not giving out ip address leases since the laptop is getting somewhat a default ip address. check the configuration if it has dhcp enabled on it. also, does the AP on building 1 appear on the wireless network list? this is the list on XP that would allow you to connect to wireless networks within range given the privilege to do so.
19 years 5 months ago #10780
by DaLight
Replied by DaLight on topic Re: wireless problem - cannot grab ip
apit, just a quick question. From your description above of the building/level wireless AP distribution, it would appear that each building has 8 APs. Are you saying that no user on any level in Building 1 can acquire an IP wirelessly? In that case, unless all the APs in Building 1 have exactly the same configuration error, I think your problem may lie somewhere else. I would look at the links between the APs and the switch in Building 1.we have 4 building..every building have 4 level..
every level have 2 AP..
so i channel the ap like this:
level 1: channel 1 channel 6
level 2: channel 6 channel 1
level 3: channel 1 channel 6
level 4: channel 6 channel 1
for every building i used 4 different SSID
every buiding also have their own switch
so all ap at every building connected to their own switch
all switch at each building will connected to core switch at data center using single mode fiber..
19 years 5 months ago #10862
by apit
Replied by apit on topic Re: wireless problem - cannot grab ip
ermm.. i'm agree with you all..
have to check the link between Ap and switch..
thanks all..
one more thing, is the channle plan is important or just set the configuration to auto?
thanks all..
