wireless problem - cannot grab ip
19 years 5 months ago #10722
by apit
yes there are..
Replied by apit on topic Re: wireless problem - cannot grab ip
also, just a quick question, are there any wireless hosts experiencing the same problem other than your laptop?
yes there are..
19 years 5 months ago #10723
by apit
ok..actually the real situation is like this..
we have 4 building..every building have 4 level..
every level have 2 AP..
so i channel the ap like this:
level 1: channel 1 channel 6
level 2: channel 6 channel 1
level 3: channel 1 channel 6
level 4: channel 6 channel 1
for every building i used 4 different SSID
every buiding also have their own switch
so all ap at every building connected to their own switch
all switch at each building will connected to core switch at data center using single mode fiber..
the problem is user at building 1 can't get ip using wireless network but others 3 building can grab ip without any problem
so is it the configuration problem or the ap itself?
19 years 5 months ago #10725
by Arani
Replied by Arani on topic situation is a solution itself
seems very clear that if that same host is able to grab an ip on all other levels, it should be able to do it in level 1 as well. check settings on the ap for level 1. i think a quick look at the channel settings will forward you towards a solution. maybe you would want to reconfigure the ap again for that level.
- The_Berzerker
- Premium Member
19 years 5 months ago #10729
by The_Berzerker
Replied by The_Berzerker on topic Re: wireless problem - cannot grab ip
It appears as a configuration problem. Are all the APs from the same vendor?? I once had a problem with a Level-One AP which wouldn't communicate witch didn't let the DHCP server to give IP to the client.
It only worked when it was acting as a DHCP server itself. Maybe that's the situation with your access point.
Let us know of any changes.
19 years 5 months ago #10731
by apit
so how to re-channel back the Ap?
Replied by apit on topic Re: situation is a solution itself
19 years 5 months ago #10732
by Arani
Replied by Arani on topic not my domain
since i have not personally configured a ap, it would be best for you to start looking at the configuration of the other ap's available to your at this moment. check their settings, and note any differences between level 1 and the other levels. if they all match, well then we are all back to square one, but if there is a glaring difference, you will know what to change. refer to the manual provided for changing settings on your ap.
Time to create page: 0.247 seconds
