Please i need immedicate help with bios
15 years 4 months ago #32862
by sose
sose
Network Engineer
Replied by sose on topic Re: Please i need immedicate help with bios
if you are good at loosing screws, you can open the laptop and take out the cmos battery and replace it, It will do you goood..
sose
Network Engineer
15 years 4 months ago #32865
by talk2sp
BORN TO BE GREAT
c0de - 3
Replied by talk2sp on topic this charlox guy...
Sose this Charlox guy is it same Charlox guy that was @ same University with Us?
Charlox i think u should do just as Sose said. But...?
BORN TO BE GREAT
c0de - 3
15 years 4 months ago #32868
by charlox01
Replied by charlox01 on topic Re: Please i need immedicate help with bios
sose, trust me as a naija guy who went to Abu, i have pieced that laptop but their is sometin about toshiba that cmos trick does not work. i hav recoupled the laptop back. i hav ran back to this forum for help i am out of options. how can i get or construct that parrallel dock Pleaseeeeeeeeeeeeeeee!
15 years 4 months ago #32869
by sose
sose
Network Engineer
hi charles glad to know you went to ABU
then follow solo's instruction
sose
Network Engineer
- lmcares4u2003
- Junior Member
15 years 4 months ago #32896
by lmcares4u2003
Replied by lmcares4u2003 on topic Re: Please i need immedicate help with bios
guy i thought is windows password , never know dat is BIOS password.........concerning dat cmos when u remove the cmos make sure its up to 10 to 15 minute even more than dat b4 fixin it back d cmos back 2 d board bcos some system has d ability 2 keep d memory or if there any jumper(clear cmos) near d cmos, u can remove it and then fix it back,,,,,,,,,,,,,,,,,sometimes u can also use d manufacturer password like dat toshiba is also toshiba,,,,,,,,or u get dis software password reset tool. pls reply
