Please i need immedicate help with bios
15 years 4 months ago #32851
by charlox01
Please i need immedicate help with bios was created by charlox01
folks, i am in a fix i reset my Toshiba satellite A220 laptop bios password because i told some friends about the old password and the abuse the privilege. so i was forced to change it last night. now the problem is that i have forgotten the new password am i am lock out. please how do i reset the bios password
thanks
charlox01
thanks
charlox01
- lmcares4u2003
- Junior Member
15 years 4 months ago #32854
by lmcares4u2003
Replied by lmcares4u2003 on topic Re: Please i need immedicate help with bios
start d system in save mode, and then login 2 ur own account or 2 d administrative account and change d password.
15 years 4 months ago #32855
by charlox01
Replied by charlox01 on topic Help on Toshiba bios password reset
guy, thanks for that advice but its not a window password. its Bios , when the system starts after the Toshiba screen its locked. if it was a window password i will have reset it since.
thanks but i need help quick someone Heeeeeelp me!
charlox01
charlox01
15 years 4 months ago #32856
Replied by S0lo on topic Re: Please i need immedicate help with bios
Unfortunately there is no straight forward hardware password reset for laptops (as it is for desktops). However, there are many things you can try, first have a read here:
www.tech-faq.com/reset-bios-password.shtml
If nothing works, then you might wana try this tool called "KeyDisk" made only for Toshiba laptops, here:
www.cgsecurity.org/wiki/CmosPwd#Toshiba
15 years 4 months ago #32858
by charlox01
Replied by charlox01 on topic Re: Please i need immedicate help with bios
www.firewall.cx ,
pls how do i use the keydisk, i hav downloaded it
thanks
www.firewall.cx ,
thanks
15 years 4 months ago #32861
I did not use it before since I don't have a Toshiba. KeyDisk is a command line tool, you need a floppy disk/drive to use it. If your laptop doesn't have one then it will not work. If it has a floppy drive, then run the KeyDisk from command prompt.
If nothing works, try creating a parallel port loopback, as shown here:
The connections for the parallel port are shown on same page above ( www.cgsecurity.org/wiki/CmosPwd#Toshiba )
Or try disconnecting the BIOS battery, (doing this one will reset the BIOS to factory defaults), here:
