subnet masks
19 years 3 months ago #10002 by Arani
Replied by Arani on topic how do i read this?
gentlemen, how do i read this?
172.16.2.0/24
19 years 3 months ago #10008 by Tarun
Replied by Tarun on topic Re: subnet masks
172.16.2.0/24
It would be interpreted as:
IP Address: 172.16.2.0
Subnet Mask: 255.255.255.0
Since the IP Address is a Class "B" Address & the Default Subnet mask for this class is 255.255.0.0, so there are 8 extra bits being used for subnetting.
So, in a nutshell, here is what it means:
172.16.2.0 is a classless IP.
/24 means there are 24 bits being used to represent the network portion which means that the subnet mask is 255.255.255.0 which inturn means there is a subnetting of 8 bits.
19 years 3 months ago #10011 by Arani
Replied by Arani on topic thanks
thanks tarun
19 years 3 months ago #10019 by mew
Replied by mew on topic Re: subnet masks
Tarun is correct in that subnetting can be done by using only one host bit. My comments were intended to stay in the context of classful subnetting. Only classless routing protocols would properly interpret classless subnetting. In other words if you are using RIP or IGRP borrowing only one bit will lead to definite routing problems.
This is not a “cisco” thing. It is understanding the difference between classful and classless routing protocols and distinguishing the difference in the subnetting rules required for each.
19 years 3 months ago #10023 by Tarun
And i thought subnetting is only classless. I have never heard anything about classfull subnetting :shock:
What are the subnetting rules required for classful routing protocols like RIP1 ?
Thanks in advance :)
19 years 3 months ago #10051 by Arani
Replied by Arani on topic in agreement with tarun
dear mew, i have to agree with tarun on the fact that there is nothing known as classfull subnetting. the moment you set a subnet mask you detach yourself away from a classful IP address which has a default subnet mask. to recall, an ip address which has a default subnet mask is called a classful IP address, the moment you are setting a new subnet mask for it, it loses its classful identify and becomes a classless IP address. i am sure tarun will agree on this.
Time to create page: 0.137 seconds
