Gateway not reachable
19 years 9 months ago #9124
by roticv
Replied by roticv on topic Re: Gateway not reachable
It seems that my router needs time to warm up
When I do not switch off my router, it works fine...
My router would fix the problem by itself most of the time. Sometimes when it is unable to do so, I would have to reboot it several times before it would cooperate.
I don't really have the money to afford a better router, so I guess I would just make do with my current one.
- Ballisaini
19 years 8 months ago #9460
by Ballisaini
Replied by Ballisaini on topic Re: Gateway not reachable
Hey dude,
I think the problem cud be with ur router or ur dsl line;In order to check reason for intermittent connection i wud suggest u to check ur DsL filters and u shud be careful with ur router not to place it near Electromagnetic interference devices like your computer monitor,lamps,speakers.As u are getting "Gateway unreachable";I wud suggest u to check whether u are able to ping all other computer on ur network so as to ensure your physical connectivity with router(NIC's),If everything is set then run "tracert" in order to find where u r loosing packets and before replacing router plz contact your ISP so that they cross checkby running ICMP tools if thats not the problem with there line.
Your Buddy,
Balli
Your Buddy,
Balli
