VOIP
19 years 10 months ago #8360 by Ranger24
Replied by Ranger24 on topic The other side....
I'd like to add my voice to this discussion, being from a telco background not dataco.
I am not sure the benefits stated really count:
1) Easy of Admin - All modern PABX (Private Automated Branch exchange) can be monitored from a single workstation, or remotely, or via a VPN - Just like call manager
2) Call re-route is also possible, though the need for it is different to a VoIP system. With a PABX the only congestion you will find is on external trunks, so routing is required to select the most appropriate trunk line based on destination, traffic level and cost. Very rarely do PABX systems have internal congestion as they have a dedicated network. You could argue it's madness to take voice from it's own dedicated network and squeeze it on to an already congested data network!(Try to convince the comms engineer of a airbase he wants to put his most vital comms traffic on data line)
3) Nice little quirks are plentiful in most PABXs. The last one I worked on (6 yrs ago) had over 200 call features (inc luding the example loosecannon cited). In terms of user features VoIP systems still have some way to go.
4) Using PC for phone calls isn't restricted to VoIP. Again this has been 'possible' from modern PABX (HiCOM, Realitis as examples) for about the last 8 yrs using TAPI (Telephony Application Prorammers Interface). Admittedly it is easier to do with VoIP systems.
The real benefit of VoIP does come with cost savings, but not in terms of call cost. The savings come with sharing the same infrastructure between voice & data (1 network, 1 set of overheads - equipment, staff & wires). So companies can reduce both their capex (Capital expenditure - equipment) and their opex (operating expenditure)
The other benefit that springs to mind is that of services. Voice networks are far superior to data networks for voice only. By moving to it all to the same data based network you are opening up a world of new possibilities - Multimedia calling, presence services, broadcast TV and so on.
I hope this helps even the debate :wink:
19 years 9 months ago #8920 by jhun
Replied by jhun on topic Re: VOIP
hi to all,
just to update this thread with regards to the topic, you could visit this site:
www.voip-info.org
where you could read and try everything with regards to voip. currently i am into asterisk (an open source pbx system) and setting it up to be a voip gateway.
15 years 8 months ago #30910 by Johnvoip
Replied by Johnvoip on topic VoipSipSdk
VoipSipSdk
I am now looking for voip solutions. And found information about Voip sdk.
According to their website www.voipsipsdk.com
Voip sdk is based on IETF standards (SIP, STUN, etc.), so it should be compatible with other standard based products such as Asterisk, OpenSER other.
They have all features I need:
# Dynamically loadable codecs
# Registrar support
# Play wav files into conversation
# Record conversation into file
# Hold/Retrieve call
# Forward Call (Blind Call Transfer)
# Transfer Call (Attended Transfer)
# Mute Sound
# VPN support
# Noise reduction
# Auto gain
# Jitter buffer parameters
# Samples on Delphi, C#, VB, VB.NET, C++ 2005, C++ 6.0, HTML (SIP ActiveX)
# Windowless samples on C++ and .NET
# DTMF
# Adaptive silence detection
# Adaptive jitter buffer
# STUN support
# Comes as ActiveX control
But before I will download the evaluation version I would like to hear other people experience.
Time to create page: 0.273 seconds
