VLAN Routing
- gagamboy
- Visitor
16 years 1 month ago #28057
by gagamboy
VLAN Routing was created by gagamboy
Hi Guys,
How can I connect/communicate two vlans in the same switch? I have configured VTP server (3560) and 2 client switch (2960).
Ideas are all welcome. Thanks a lot.
Cheers!
Gagamboy
Cheers!
Gagamboy
16 years 1 month ago #28061
Replied by S0lo on topic Re: VLAN Routing
You need a router or layer 3 switch to be able to allow communication between VLANs. As far as I know, the 3560 switch is a layer 3 switch. So you don't need an extra router to do it
Briefly, you have to first enable routing by using the ip routing command. Then define VLAN interfaces and IPs/masks on them (These are virtual interfaces). Full details are here: www.cisco.com/en/US/tech/tk389/tk815/tec...186a008019e74e.shtml
And this might help you understand how routing between VLANs works: www.firewall.cx/vlans-routing.php
- gagamboy
- Visitor
16 years 1 month ago #28077
by gagamboy
Replied by gagamboy on topic Re: VLAN Routing
Great, nice link. Thanks Solo..
cheers!
Gagamboy
cheers!
Gagamboy
16 years 1 month ago #28082
Your more than welcome gagamboy
- gagamboy
- Visitor
16 years 1 month ago #28084
by gagamboy
Hi Solo,
I have tried your suggestion and follow the link but it seems that the PC in different VLANs cannot see each other (ping).
I dont know what I am missing in configuration but I think there might be problem in trunking of switches??? It is my first time to use a VTP.
Thanks in advance.
Cheers!
Gagamboy
Thanks in advance.
Cheers!
Gagamboy
16 years 1 month ago #28087
Hello gagamboy
Make sure the windows firewall (Or any other firewall) is turn OFF on the PC your are pinging (the remote PC). Or configure the firewall to allow ping.
If that doesn't work, it might help us to see your configs with a brief description of how things are connected.
By the way, for a moment I thought that sahir was back when I saw your avatar :lol:
Time to create page: 0.128 seconds
