Are ADSL filters required if you are not using it for Voice?
18 years 4 months ago #18534 by Smurf
So, just got off the phone with an ISP who will not do any fault diagnosis with me on my ADSL line which keeps disconnecting every afternoon. The Debug on the Cisco routers seems to suggest that the issue is at the ISP end because we get as far as PPP "No Remote Authentication for Call-Out" and then it goes into LCP stuff instead of then starting a CHAP challenge.
Anyhow, I have been told that before they can log this with BT, i will HAVE TO install a filter, even though we do not have a telephone plugged into the phone line since its only used for ADSL.
Am i right here in that if you are not using voice over it, why do you need to split the frequency for Voice and Data ? Doesn't make any sense to me ?
18 years 4 months ago #18535 by DaLight
As far as I understand, the filter simply blocks the lower frequency components of the signal required for voice and allows the higher frequency components through to your modem (and the reverse for your phone)
I would think if you had to use a filter without a phone connected, you probably have other issues.
However, I stand to be corrected.
18 years 4 months ago #18569 by TheBishop
I always thought the filter was for the phone's benefit rather than the modem. However there's a simple remedy; just stick a filter in, prove the fault is still there and then call them out! If you need to borrow a filter I've got a spare so give me a shout
18 years 4 months ago #18572 by Smurf
Cheers for the offer but one of the lads at work has a spare one to just test :)
18 years 4 months ago #18606 by GTM
If you are getting dsl on your router which i gather you are as you are getting to the ppp stage which means you are synced up with the isp's line then a microfilter wont make any difference as the problems an authentication issue not a physical connection one.
18 years 4 months ago #18619 by Smurf
Thats a very good point, if i am getting PPP on layer 2 then layer 1 must be ok :)
