How BRAS actually work in detail (Root level information)
18 years 7 months ago #16392
by Ranger24
Replied by Ranger24 on topic Re: How BRAS actually work in detail (Root level information)
B-RAS & Radius Server interaction can work in a number of ways. The example below is a typical example
1. User (CPE or User PC can do this) initiates PPP authentication to the B-RAS
2. B-RAS prompts for username and password (if Password Authentication Protocol [PAP]) or challenge (if Challenge Handshake Authentication Protocol [CHAP]).
3.User replies.
4. Once the user is authenmticated by the B-RAS it sends the username and encrypted password to the RADIUS server. (Access Request)
5. RADIUS checks this against its database and responds with Accept, Reject, or Challenge.
5a. If the user exists and the password is correct the the server sends "Access-Accept"
5b. If the user does not exist or password is incorrect then the server sends "Access-Reject"
5c The server can send "Access-Challenge" (random number) to the B-RAS The B-RAS must respond correctly for authentication to be complete. This is optional and dependant on the authentication model required.
6. The B-RAS acts upon services (i.e supplies require IP from a pool or relases static IP) and services parameters (i.e. QoS) as bundled with Accept or Reject.
I hope this helps.
R
3.User replies.
I hope this helps.
R
18 years 4 months ago #18852
by unlight
Replied by unlight on topic Re: How BRAS actually work in detail (Root level information)
Hi there,
Just wondering if someone could confirm some B-RAS synonyms for me: RAN (remote access node) and ERX (edge router ...?) - are these one and the same or are they different pieces of equipment serving different functions in a broadband network?
thanks!
thanks!
18 years 4 months ago #18856
by Ranger24
Hi Unlight,
Welcome to firewall!
With regards to your question:
RAN - Remote Access Node (or if Mobile broadband Radio Access Network)
ERX - Not a synonym but a product name/ ERX was (is?) a B-RAS sold by siemens/juniper
Hope that helps
R
Hope that helps
R
18 years 4 months ago #18910
by unlight
Hiya, thanks for the info and welcome (: I was trying to clarify a diagram I got of my countries DSL network.
