Need help for my packet tracer ~
14 years 1 month ago #36388
by JYghost
Replied by JYghost on topic Re: Need help for my packet tracer ~
thx alot ! (: bt i tried to change the switch to client mode bt it still turn dark green ? why ??
14 years 1 month ago #36389
by JYghost
erm SRY WRONG POST !~
14 years 1 month ago #36391
by Nevins
Below is an example:
!--- The access-list 101 denies icmp from any to any network
!--- but permits IP traffic from any to any network.
router#configure terminal
Enter configuration commands, one per line. End with CNTL/Z.
router(config)#access-list 101 deny icmp any any
router(config)#access-list 101 permit ip any any
router(config)#^Z
router#show access-list
Extended IP access list 101
deny icmp any any
permit ip any any
router#
This has been taken from this page: www.cisco.com/en/US/products/sw/secursw/...186a00800a5b9a.shtml
You should note that unlike other things being blocked by an access control list ping is part of ICMP not TCP or UDP and therefore has no port to block.
Useful Threads
Replied by Nevins on topic Re: Need help for my packet tracer ~
and if i wanted to set up ACL to block warehouse to ping payroll, how to i go about it ?
router(config)#^Z
deny icmp any any
permit ip any any
router#
Useful Threads
14 years 1 month ago #36393
by JYghost
www.sendspace.com/file/x6vs55
y cant i ping from hosts in Orchard(10.1.1.x) to router
(JurongIndustrial) ?
anyway thank alot for helping me ! (:
quite confuse about it, cause when i ping the host to the router,it successful bt when i ping from the router to host, it fail ~ why is it like this ? is it i configure the router wrongly ?
thank nevins ! (:
thank nevins ! (:
14 years 1 month ago #36395
by Nevins
Useful Threads
Sending 5, 100-byte ICMP Echos to 10.1.3.65, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 11/12/13 ms
JurongIndustrial#
Which one are you trying to ping from? Above is the result I got when I tried loading the file.
JurongIndustrial#
Useful Threads
14 years 1 month ago #36396
by JYghost
ok the second time i tried to ping the router to PC, it success.
but now there's some problems for this:
HQAdmin ping to JurongIndustrial - Fail
JurongWarehouse to ChangiSouth - Success
JurongLogistic to ChangiSouth - Fail
dun really understand ...
