Need help for my packet tracer ~
14 years 1 month ago #36367 by JYghost
www.2shared.com/file/nLJcu--K/Case_Study_vlan.html
I cant ping the host and the router. And what ip add should i put for my vlan ? Please help me ! ):
14 years 1 month ago #36371 by Nevins
File Attachment:
Which host and which router are you trying to get to communicate?
Useful Threads
14 years 1 month ago #36373 by JYghost
i'm trying to make the three routers able to communicate to all hosts . is that possible ?
14 years 1 month ago #36380 by S0lo
I had a look at it. Here are some points that you need to consider.
1. Since your using VLANs every where, you need to define sub-interface on the FastEthernet ports of all routers.
2. The switch ports connected to those router ports should also be set to trunk mode.
3. Some PCs are not using the correct subnet mask and gateway.
4. The switches are all on VTP server mode. Only one switch per switching segment should be set to server mode, the rest should be client mode. Still, if you don't do this one, the network will work. but it's not practical to all on server mode since you need to update all switched manually for VLAN changes.
I fixed only the LEFT side of the network, the side behind the "Jurong Industrial" Router. Those PCs on the left can now ping each other. I'll leave the rest to you ;). Here is the half-fixed file:
www.2shared.com/file/HkRhNpG5/Case_Study_vlan_half_fixed.html
14 years 1 month ago #36382 by JYghost
is there other link to download the file ?? sry i cant download it ..
14 years 1 month ago #36383 by S0lo
Here it is with a different host:
www.sendspace.com/file/h5ngdm
