i am satish, i have a some problem about the NAT.
15 years 6 months ago #31895 by ZiPPy
I wanted to add instead of edit my previous statement regarding addressing. You could use a different mask, but this will increase the broadcasts on the network. Therefore, in order to preserve and IP addresses, you could always create VLANs on your network.
Just a random thought that crossed my mind regarding this topic.
ZiPPy
ZiPPy
15 years 6 months ago #31901 by Swapnil_dharam
Dear Satish,
As per my understanding 124.124.211.145 is the IP of ur serial port of router and 192.168.1.1 is the internal gateway configured on eth0 of the router. If I am right abt ur given sinerio than configuration would look like below:-
interface Ethernet0/0
ip nat inside
ip access-group 1 in
interface Serial0/0
ip address 124.124.211.145 [here u can put the subnet mask given by reliance]
ip nat outside
ip nat inside source list 1 interface serial0/0 overload
access-list 1 permit 192.168.1.0 0.0.0.255
But still I have question in my mind that where U configured secong global IP 124.124.211.146 provided by reliance.
Regards,
Swapnil
15 years 6 months ago #31905 by next_virus
Swapnil /Satty,
The Static IP provided by reliance is only one that is 124.124.211.145
and 124.124.211.146 is the gateway of 124.124.211.145.
Am I right Satty.
NAT can be used at router (I don't have any idea about L3 switch) and as suggested by Zippy you can create different VLANS on your switch.
Regards.
15 years 6 months ago #31926 by Swapnil_dharam
Hey It seems that, 124.124.211.146 is the other end ip add, then no issue.
In this case my above PAT configuration will definately work.
