MPLS - Frame Relay Traffic Shaping
15 years 2 months ago #32082
by ZiPPy
ZiPPy
MPLS - Frame Relay Traffic Shaping was created by ZiPPy
We recently upgraded from 3 T1 circuits (4.5MB) to 5 T1 circuits (7.5MB) at the office. During the upgrade we experienced some high latency issues. These issues might have already existed, but were overlooked. With the ISP on the phone during the setup, they were the ones who caught it.
The config is as followed:
interface MFR1
description connected to MPLS
no ip address
frame-relay traffic-shaping
frame-relay lmi-type ansi
interface MFR1.682 point-to-point
bandwidth 4608
ip address x.x.x.x 255.255.255.252 *IP removed for forum
frame-relay interface-dlci 682 IETF
class SD
map-class frame-relay SD
frame-relay cir 4608000
frame-relay mincir 4608000
service-policy output SD-VoIP
The ISP engineer informed me to remove the following lines:
class SD
New config:
interface MFR1
no ip address
bandwidth 7680
frame-relay interface-dlci 735 IETF
frame-relay cir 7680000
frame-relay mincir 7680000
From what I understand, the Frame-Relay traffic shaping is designed to control the amount of traffic the router sends out a specific interface or particular DLCI. My question is, why would this command have caused such high latency? We are talking close to 1000ms. Once that was removed, the latency dropped. But the class still exists. I'm just a little confused on how it works.
ZiPPy
interface MFR1
no ip address
bandwidth 4608
class SD
class SD
New config:
interface MFR1
no ip address
bandwidth 7680
ZiPPy
ZiPPy
15 years 1 month ago #32183
by Kajitora
itgamers.blogspot.com
Replied by Kajitora on topic Re: MPLS - Frame Relay Traffic Shaping
Hmm, Could I see the SD-VoIP policy?
Frame-relay traffic-shaping is put on primary interface to allow you to apply specific policy to a sub interface.
The "class SD" applied the below to the interface.
The:
is no longer applied to that interface, so it no longer effects the traffic. What bothers me about this being removed is it looks like you also striped it of its VoIP QoS.
The:
15 years 1 month ago #32192
by ZiPPy
ZiPPy
Replied by ZiPPy on topic Re: MPLS - Frame Relay Traffic Shaping
This raises a great amount of suspicions if QoS is working or not. Secondly, I need to find how to put the 'class SD' back into the configuration. Simply adding the 'class SD' line back into the router will crash it. How do I know this? Because I did it.
I'm currently investigating the issue.
ZiPPy
ZiPPy
ZiPPy
15 years 1 month ago #32207
Replied by S0lo on topic Re: MPLS - Frame Relay Traffic Shaping
I would revise the bandwidth values in the following lines:
[code:1]bandwidth 4608
frame-relay mincir 4608000[/code:1]
4608 means 4608kbps, and 4608000 means 4608000bps. It's looks like these are the old speeds for the 3 T1 circuits (4.5Mbps = 1024 X 4.5). Try to changing them to 7680 and 7680000 (i.e 7.5bps = 1024 X 7.5). So the lines would be:
[code:1]bandwidth 7680
frame-relay mincir 7680000 [/code:1]
Just a guess, there might be other things too.
15 years 1 month ago #32212
by ZiPPy
ZiPPy
I totally agree S0lo, but I already have the frame-relay cir 7680000 set, as you can see from Kajitora's post.
My question at hand right now is how removing the 'class SD' ties in to everything, and why placing it back into the config crashes the router.
This VoIP stuff is an entirely different world, yet this is all part of the Routing & Switching environment. I need to read up more and research this more in-depth. Still have something fishy going on, but not big enough to break the entire system.
Working on it...
ZiPPy
Working on it...
ZiPPy
ZiPPy
15 years 1 month ago #32215
ZiPPy,
Silly I didn't see that 7680000 above :oops:. I better stop posting at bed time.
Time to create page: 0.135 seconds
