Comcast to Cisco Help
15 years 2 months ago #31876 by ZiPPy
Replied by ZiPPy on topic Re: Comcast to Cisco Help
This might give you some direction. I managed to configure a Cable modem with a static IP and using NAT.
Link: www.firewall.cx/ftopict-6522-.html
ZiPPy
ZiPPy
15 years 2 months ago #31944 by Kenjo56
Replied by Kenjo56 on topic Re: Comcast to Cisco Help
Thanks Gentelmen, it appears the problem was that I was using a standard access list, when I should have been using an extended access list. I altered my original configuration, and it works just fine. The last two suggestions helped. I found my mistake at:
Kenjo56
15 years 2 months ago #31947 by ZiPPy
I love when older posts help people. I have found the exact issues described on various forums, but more often than not the resolution is never posted. Heck, sometimes the thread just dies in the middle of a discussion.
I'm glad you found your answer Kenjo56! I will be looking into access lists in-depth soon. These guys can be pretty tricky.
Cheers mate,
ZiPPy
ZiPPy
15 years 2 months ago #31951 by S0lo
Replied by S0lo on topic Re: Comcast to Cisco Help
Glad it worked for you. Although I'm really not sure why NAT didn't work with a standard ACL and worked with an extended ACL :? Both should work!!. I've done it before using a standard ACL and Cisco says it can be done here:
www.cisco.com/en/US/tech/tk648/tk361/tec...186a0080094e77.shtml
Unless you meant a different ACL or I'm missing some thing here.
Time to create page: 0.127 seconds
