Comcast to Cisco Help
15 years 7 months ago #31856
by Kenjo56
Comcast to Cisco Help was created by Kenjo56
I reset the Comcast modem. and my Fa0/1 interface which was configured with, ip address dhcp was immediately assigned an ip address from comcast. Great!!! I can ping the comcast gateway from my router, and other devices can ping the routers Fa0/1 interface which recieved it address from comcast dhcp, but I still can't ping past the the Fa0/1 interface from any other device. So I got this far by resesting the modem, but now I'm stuck. Hope I made sense. Any thoughs?
15 years 7 months ago #31858
by ZiPPy
ZiPPy
Replied by ZiPPy on topic Re: Comcast to Cisco Help
Can you post your configuration of the router, so we can take a look.
ZiPPy
ZiPPy
ZiPPy
15 years 7 months ago #31862
by Kenjo56
Replied by Kenjo56 on topic Comcast - Cisco Continued
Thanks ZIPPy,
I have a 2621 connected to a MLS lab and a frame-relay lab. Just thought I connect to the real world through my Comcast home cable modem. I tried configuring a default route and gateway, but either I configured wrong or thats not the solution. Appreciate you looking. Just passed the 802 now I started with the CCNP certification.
Kenjo56
version 12.2
service timestamps log uptime
hostname IVR
enable secret 5 $1$KEzH$rCG1KwXNKWfa4fzLGk/xq0
ip subnet-zero
interface FastEthernet0/0
ip address 10.10.10.254 255.255.255.0
duplex auto
speed auto
interface Serial0/0
ip address 10.1.12.2 255.255.255.0
no fair-queue
clockrate 64000
interface FastEthernet0/1
ip address dhcp
duplex auto
speed auto
interface Serial0/1
no ip address
shutdown
router eigrp 25
network 10.1.10.0 0.0.0.255
network 10.1.12.0 0.0.0.255
network 10.10.10.0 0.0.0.255
auto-summary
ip classless
ip http server
banner motd This is the IVR
line con 0
exec-timeout 60 0
password cisco
logging synchronous
login
line aux 0
line vty 0 4
password cisco
login
line vty 5 15
password cisco
login
end
Kenjo56
version 12.2
hostname IVR
ip subnet-zero
duplex auto
speed auto
interface Serial0/0
no fair-queue
clockrate 64000
ip address dhcp
duplex auto
speed auto
interface Serial0/1
no ip address
shutdown
router eigrp 25
auto-summary
ip classless
ip http server
line con 0
exec-timeout 60 0
password cisco
logging synchronous
login
line aux 0
line vty 0 4
password cisco
login
line vty 5 15
password cisco
login
end
15 years 7 months ago #31864
Replied by S0lo on topic Re: Comcast to Cisco Help
I'm assuming here that the Comcast modem is not doing NAT nor routing and that the IP that Fa0/1 got via DHCP is a public IP. If it's a private IP (like 192.168.x.x or 10.x.x.x), then the following will probably not work.
You first need to setup NAT. Try the following (I'm assuming that your internal hosts are connected to the Fa0/0):
[code:1]interface FastEthernet0/0
ip nat inside
ip nat outside
ip nat inside source list 1 interface FastEthernet0/1 overload
access-list 1 permit 10.10.10.0 0.0.0.255
For more info on NAT you could try our guide: www.firewall.cx/tk-cisco-routers-nat-overload.php
Then as you said you need a default route, some thing like this:
[code:1]ip route 0.0.0.0 0.0.0.0 <gateway_IP>[/code:1]
Replace <gateway_IP> with the IP of the gateway. Or if you can't know it, you could use:
[code:1]ip route 0.0.0.0 0.0.0.0 FastEthernet0/1[/code:1]
Hope it helps
ip nat inside
ip nat outside
Hope it helps
15 years 7 months ago #31865
by Kenjo56
Replied by Kenjo56 on topic Continued..
I appreciate your suggestion, I thought NAT might be a solution. I tried your suggested configuration. I appear to be getting a genuine IP address from Comcast 69.139.12.217. It is in the same range as the address assigned by Comcast when connected with my Wireless Router, 69.136.86.? Anyway I still can't ping past the Fa0/1 interface.
If I can't resolve this issue for now, I got plenty other work, but if you have any thoughts...
Kenjo56
Kenjo56
15 years 7 months ago #31869
Just to make sure this is not a DNS issue, could you try pinging the DNS server from a PC behind Fa0/0 ?
