3550 switch vlan
15 years 8 months ago #31435
by mic
Replied by mic on topic Re: 3550 switch vlan
Switch#show int vlan 5
Vlan0005 is up, line protocol is up
Hardware is CPU Interface, address is (bia )
Internet address is 192.168.1.3 /24
MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
reliability 255/255, txload 1/255, rxload 1/255
Auto-duplex, Auto-speed
Encapsulation ARPA, loopback not set
ARP type: ARPA, ARP Timeout 04:00:00
Last input 02:29:44, output never, output hang never
Last clearing of "show interface" counters never
Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 0
Queuing strategy: fifo
Output queue :0/40 (size/max)
5 minute input rate 0 bits/sec, 0 packets/sec
5 minute output rate 0 bits/sec, 0 packets/sec
269 packets input, 71059 bytes, 0 no buffer
Received 6 broadcasts, 0 runts, 0 giants, 0 throttles
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored
7290 packets output, 429075 bytes, 0 underruns
0 output errors, 3 interface resets
0 output buffer failures, 0 output buffers swapped out
Switch#show int vlan 10
Vlan0010 is up, line protocol is up
Internet address is 10.10.10.3 /24
Switch#show int fe 0/11.1
FastEthernet0/11.1 is up, line protocol is up
Hardware is Fast Ethernet, address is 000C.5521.2494 (bia 000C.5521.2494)
Internet address is 192.168.4.10 /24
MTU 1500 bytes, BW 10000 Kbit, DLY 1000 usec,
Switch#show int fe 0/11.2
FastEthernet0/11.2 is up, line protocol is up
Internet address is 10.10.9.10 /24
15 years 8 months ago #31436
by mic
Router#show run
Building configuration...
Version 12.1
service timestamps log uptime
hostname Router
ip cef
ip subnet-zero
interface Serial0
no ip address
no ip directed-broadcast
interface Serial1
no ip address
interface FastEthernet0/0
no ip address
interface FastEthernet0/0.1
ip address 192.168.4.254 255.255.255.0
interface FastEthernet0/0.2
ip address 10.10.9.254 255.255.255.0
interface FastEthernet0/1
no ip address
ip classless
no ip http server
line con 0
transport input none
line aux 0
line vty 0 4
no scheduler allocate
end
Version 12.1
hostname Router
ip cef
ip subnet-zero
interface Serial0
no ip address
interface Serial1
no ip address
no ip address
no ip address
ip classless
no ip http server
line con 0
line aux 0
line vty 0 4
end
15 years 8 months ago #31437
by mic
Router#show int fe 0/0.1
FastEthernet0/0.1.1 is up, line protocol is up
Internet address is 192.168.4.254/24
MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec, rely 255/255, load 1/255
Encapsulation ARPA, loopback not set, keepalive set (10 sec)
Auto-duplex, Auto Speed, 100BaseTX/FX
Router#show int fe 0/0.2
FastEthernet0/0.2.2 is up, line protocol is up
Internet address is 10.10.9.254/24
Switch#config t
Enter configuration commands, one per line. End with CNTL/Z.
Switch(config)#access-list 101 deny tcp 10.10.10.0 0.0.0.255 192.168.1.0 0.0.0.255 any
% Invalid input detected at '^' marker.
Switch(config)#access-list 101 deny ip 10.10.10.0 0.0.0.255 192.168.1.0 0.0.0.255 any
the commands that wont take thaks evertone they will not be long again___ thank you
Switch#config t
15 years 8 months ago #31438
by mic
Reminder this is just atest with two vlans the i worry about 3?
thankyou so much everyone for responding
15 years 8 months ago #31439
by mic
one more thing if you have a layer 3 switch you no not have to trunk to router RIGHT? SOMEONE TOLD ME YOU DO? THANKS AGAIN
15 years 8 months ago #31441
by mic
thank you to eveyone and sorry i took up your time, BOSON has finaly admited that it will not take extended access-lists after a week with them going back and forth even thow it is in there program labs? thanks again and hope when i have other things to post it dont hurt my rep. thanks
