3550 switch vlan
15 years 8 months ago #31179
by mic
3550 switch vlan was created by mic
newbe mic?? i have a 3550 emi switch and made 3 vlans for my test lab, so i do not what the vlans to access each other ( because i am going to have three domains ), i am on boson testing this, i made access-lists and apply them to the vlan interface for the vlans cannot access each other, and apply them the right way and they show up in sh run command, but no matter what i do everything can ping each other?? counld this be boson not working righ??? thanks all anyting will help get on track?? p.s. also disable ip routing also>
15 years 8 months ago #31187
Replied by TheBishop on topic Re: 3550 switch vlan
You're right, with three separate VLANs and no inter-VLAN routing you shouldn't be able to ping from one to the other. Something must be not quite right here. Do the VLANs show up when you do a show vlan?
- skepticals
- Elite Member
15 years 8 months ago #31201
by skepticals
Replied by skepticals on topic Re: 3550 switch vlan
Can you post the config?
15 years 8 months ago #31203
Replied by Chris on topic Re: 3550 switch vlan
Everything sounds like you've got a correct setup, however there must be a problem with the configuration that could explain this behaviour.
Can you post us your running configuration so that we can examine it?
15 years 8 months ago #31341
by Nitishh
Replied by Nitishh on topic Re: 3550 switch vlan
do a show ip route on the switch . If it is an 3550 EMI then routing must be enable by default . post your show ip route info
15 years 8 months ago #31434
by mic
Replied by mic on topic Re: 3550 switch vlan
sorry it took so long had to go away( rember i am putting 3 domains on real test network so do not want vlans to talk, on boson now testing but boson will not take the access-list commads ( or am i doing something wrong) have to have ip routing on for later when i use routing protocols, i took a lot of snap shots and going to try to apply them now for you can see where i stand??
Switch# show vlan
VLAN Name Status Ports
1 default active Fa0/6, Fa0/7, Fa0/8, Fa0/9
Fa0/10, Fa0/11, Gi0/1, Gi0/2
5 pc1 active Fa0/1, Fa0/2, Fa0/3
10 pc2 active Fa0/4, Fa0/5, Fa0/12
1002 fddi-default active
1003 token-ring-default active
1004 fddinet-default active
1005 trnet-default active
VLAN Type SAID MTU Parent RingNo BridgeNo Stp BrdgMode Trans1 Trans2
1 enet 100001 1500 - - - - - 0 0
5 enet 100005 1500 - - - - - 0 0
10 enet 100010 1500 - - - - - 0 0
1002 fddi 101002 1500 - - - - - 0 0
1003 tr 101003 1500 - - - - - 0 0
1004 fdnet 101004 1500 - - - ieee - 0 0
1005 trnet 101005 1500 - - - ibm - 0 0
Switch#show run
Version 12.1
service timestamps log uptime
hostname Switch
ip cef
ip subnet-zero
ip routing
spanning-tree extend system-id
interface FastEthernet0/1
switchport mode access
switchport access vlan 5
interface FastEthernet0/2
interface FastEthernet0/3
interface FastEthernet0/4
switchport access vlan 10
interface FastEthernet0/5
interface FastEthernet0/6
interface FastEthernet0/7
interface FastEthernet0/8
interface FastEthernet0/9
interface FastEthernet0/10
interface FastEthernet0/11
switchport port-security
interface FastEthernet0/11.1
ip address 192.168.4.10 255.255.255.0
interface FastEthernet0/11.2
ip address 10.10.9.10 255.255.255.0
interface FastEthernet0/12
interface GigabitEthernet0/1
interface GigabitEthernet0/2
vtp mode Server
vtp domain bigdomain
interface Vlan 1
no ip address
no ip route-cache
no ip route-cache
no ip route-cache
interface Vlan0005
ip address 192.168.1.3 255.255.255.0
no ip route-cache
interface Vlan0010
ip address 10.10.10.3 255.255.255.0
no ip route-cache
vlan 5 name pc1
vlan 10 name pc2
ip classless
no ip http server
line con 0
transport input none
line aux 0
line vty 0 4
no scheduler allocate
end
post more on nother this one will take no more
Switch# show vlan
Switch#show run
Version 12.1
hostname Switch
ip cef
ip subnet-zero
ip routing
vtp mode Server
interface Vlan 1
no ip address
no ip route-cache
no ip route-cache
no ip route-cache
interface Vlan0005
no ip route-cache
interface Vlan0010
no ip route-cache
vlan 5 name pc1
vlan 10 name pc2
ip classless
no ip http server
line con 0
line aux 0
line vty 0 4
end
