VLAN "stretching" over frame relay (WAN in general
15 years 10 months ago #30478
by ninriggs
Replied by ninriggs on topic Re: VLAN "stretching" over frame relay (WAN in general
A content switch would work if you can have an interface on each network - then present a VIP to the clients.
fail over or redundancy is set up internally and there are many options for the type of load balance you need
we use ACE modules and older css5 series (all cisco)
however.
A Content switch is really to present a single vip to an outside network - this does seem like an over complicated solution to the problem.
Please let me get the idea straight.
You have two seperate networks. your clients connect to either of them at the moment.
You want to use both connections to "load balance" for the clients.?
i ask in case im miles off (sorting out a few things whilst typing this)
however.
Time to create page: 0.167 seconds
