Cisco Lab (WANs)
16 years 1 month ago #29736 by S0lo
Replied by S0lo on topic Re: Cisco Lab (WANs)
Do Cisco routers not like the prefix notation for the subnet?
As far as I know, It depends on the command. For ip address, NO. But for example in DHCP pools, you can do network 192.168.1.0 /24
16 years 4 weeks ago #29758 by ZiPPy
Replied by ZiPPy on topic Re: Cisco Lab (WANs)
S0lo,
Here is the output:
File Attachment:
ZiPPy
16 years 4 weeks ago #29760 by SteveP
Replied by SteveP on topic Re: Cisco Lab (WANs)
What about show control serial 0 and show run for each router?
16 years 4 weeks ago #29762 by S0lo
Sounds more like a problem in the physical level/layer. So I'd check that the two heads of the serial cable is firmly connected. How about trying another cable. I doubt it's a clock rates DCE/DTE problem, since it should have shown UP in status and DOWN in protocol.
Posting a show run of both routers might help us as SteveP recommended
16 years 4 weeks ago #29770 by ZiPPy
I reseated the cables and changed the encapsulation to ppp. I can now send pings between both routers. Pulling and running cables in a Cisco network can always dislodge and disconnect cables. This proves to show that one should never overlook troubleshooting at the physical layer. If your sure its not the physical layer ...check one more time to be extra sure!!!
Thanks for the help guys!!
ZiPPy
ZiPPy
16 years 4 weeks ago #29775 by S0lo
Glad it worked :)
