Cisco Lab (WANs)
16 years 1 month ago #29674 by ZiPPy
Cisco Lab (WANs) was created by ZiPPy
I have setup a Cisco lab and attempting to create a WAN lab. I have 2 Cisco 1700 routers connected to each other through a DCE/DTE cable. I am attempting to mimic a WAN connection between the two routers.
I have the DCE setup for clocking at a clock rate of 64000. I am unable to bring the serial interface up. Both status and protocol are down.
I have run the 'no shutdown' command on the serial 0 interface on both the DCE and DTE routers. Am I missing something? Is there something different in bringing up these connections in a lab environment using DCE/DTE?
ZiPPy
ZiPPy
16 years 1 month ago #29678 by ZiPPy
Replied by ZiPPy on topic Re: Cisco Lab (WANs)
I have looked at this problem from every angle.
Verified hardware is functional
Entered the following:
R1(config-if)# interface serial 0
R1(config-if)# ip address 172.17.0.1 /16
R1(config-if)# clock rate 64000
R1(config-if)# no shutdown
I know for a fact this is correct! Still no go!!!
ZiPPy
ZiPPy
16 years 1 month ago #29680 by Chris
Replied by Chris on topic Re: Cisco Lab (WANs)
zIPPY,
Try setting your encapsulation to ppp on both sides, also check the controller/interface (sh interfaces).
Let us know of your results.
16 years 1 month ago #29721 by ZiPPy
I've set both sides to use encapsulation ppp.
I ran a show ip interface brief which gave me the following for the serial 0 interface.
Status: down Protocol: down
OK?: yes and method: manual
ZiPPy[/b]
ZiPPy
16 years 1 month ago #29726 by S0lo
Replied by S0lo on topic Re: Cisco Lab (WANs)
Hi Zippy,
Could you copy/paste that show ip interface brief output here.
By the way, the line:
[code:1]R1(config-if)# ip address 172.17.0.1 /16 [/code:1]
Should be done like this:
[code:1]R1(config-if)# ip address 172.17.0.1 255.255.0.0 [/code:1]
I'm sure you know this but just in case.
16 years 1 month ago #29733 by ZiPPy
S0lo,
Do Cisco routers not like the prefix notation for the subnet? I wonder if that is my problem. But I'm pretty sure when I entered the subnet mask I typed it out. I'll copy/paste the output this evening when I am home.
Thanks!!
ZiPPy
ZiPPy
