ASA 5505 Port forwarding setup
18 years 6 months ago #25270 by flipzz
Here is my config. I am tryignt o make web traffice go from outside IP (XXX.XXX.184.74) to the internal Server on 192.168.2.2.
Can not get the traffic to route thru. Any pointers would be appreciated.
ASA Version 7.2(3)
hostname iconnect
enable password XXXXXXXXXXXXXXX encrypted
names
interface Vlan1
nameif inside
security-level 100
ip address 192.168.2.1 255.255.255.0
interface Vlan2
nameif outside
security-level 0
ip address XXX.XXX.184.74 255.255.255.0
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
passwd XXXXXXXXXXXXX encrypted
ftp mode passive
dns server-group DefaultDNS
access-list outside_access_in extended permit tcp any 255.255.255.0 host XXX.XXX.184.74 eq www
pager lines 24
logging enable
logging asdm informational
mtu inside 1500
mtu outside 1500
asdm image disk0:/asdm-523.bin
no asdm history enable
arp timeout 14400
static (inside,outside) XXX.XXX.184.74 192.168.2.2 netmask 255.255.255.255
route outside 0.0.0.0 0.0.0.0 XXX.XXX.184.1 1
timeout xlate 3:00:00
http server enable
http 192.168.2.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd auto_config outside
dhcpd address 192.168.2.2-192.168.2.254 inside
dhcpd dns XXX.XXX.184.14 XXX.XXX.3.6 interface inside
dhcpd enable inside
class-map inspection_default
parameters
message-length maximum 512
policy-map global_policy
class inspection_default
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
username XXXXX password XXXXXXXXXXX encrypted
prompt hostname context
Cryptochecksum:6903dcf72fef0b179623f43855d75004
: end
ciscoasa#
18 years 6 months ago #25272 by Elohim
apply the access-list to the outside interface inbound:
Also, you don't have a global pool, so non of your inside devices will be able to send traffic outside except the server 192.168.2.2. You'll need a global pool or set it to do PAT on the outside interface.
ASA Version 7.2(3)
hostname iconnect
names
interface Vlan1
nameif inside
security-level 100
interface Vlan2
nameif outside
security-level 0
ftp mode passive
pager lines 24
logging enable
mtu inside 1500
mtu outside 1500
arp timeout 14400
http server enable
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd enable inside
parameters
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
: end
ciscoasa#
18 years 6 months ago #25287 by flipzz
Still having problems getting web traffic to go from the outside world to the inside server. I do packet trace and it is being stopped at access rules. Below is config I have now. Any more pointers are greatly appreciated.
ASA Version 7.2(3)
hostname iconnect
enable password XXXX encrypted
names
interface Vlan1
nameif inside
security-level 100
interface Vlan2
nameif outside
security-level 0
ip address 216.XXX.XXX.74 255.255.255.0
ftp mode passive
access-list outside_access_in extended permit tcp any eq www host 192.168.2.2 eq www
pager lines 24
logging enable
mtu inside 1500
mtu outside 1500
arp timeout 14400
static (inside,outside) 216.XXX.XXX.74 192.168.2.2 netmask 255.255.255.255
route outside 0.0.0.0 0.0.0.0 216.XXX.XXX.1 1
http server enable
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd dns 216.XXX.XXX.14 207.170.3.6 interface inside
dhcpd enable inside
parameters
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
username XXXXXX password XXXXXX encrypted
: end
iconnect#
18 years 6 months ago #25290 by Elohim
Your access-list is not correct and you haven't bound any access list to any interfaces. The access list in your first post with your full configuration was correct.
ASA Version 7.2(3)
hostname iconnect
names
interface Vlan1
nameif inside
security-level 100
interface Vlan2
nameif outside
security-level 0
ftp mode passive
pager lines 24
logging enable
mtu inside 1500
mtu outside 1500
arp timeout 14400
http server enable
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd enable inside
parameters
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
: end
iconnect#
