ASA 5505 Port forwarding setup
17 years 2 months ago #25166
by flipzz
ASA 5505 Port forwarding setup was created by flipzz
I am setting up a basic config for our firewall. I am trying to make it so inside traffic goes outside fin (this works) and outside traffic only comes in on specified ports. (ex. port 25 goes to internal ip of 192.168.2.6). I am stuck. below is my config, any recommendations to this would be great.
: Saved
ASA Version 7.2(3)
hostname ciscoasa
enable password XXXXXXXXX encrypted
names
interface Vlan1
nameif inside
security-level 100
ip address 192.168.10.1 255.255.255.0
interface Vlan2
nameif outside
security-level 0
ip address XXX.XXX.184.51 255.255.255.0
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
passwd XXXXXXXXXXXXX encrypted
ftp mode passive
pager lines 24
logging asdm informational
mtu outside 1500
mtu inside 1500
no asdm history enable
arp timeout 14400
global (outside) 1 interface
route outside 0.0.0.0 0.0.0.0 XXX.XXX.184.1 1
timeout xlate 3:00:00
http server enable
http 192.168.10.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd auto_config outside
dhcpd address 192.168.10.2-192.168.10.254 inside
dhcpd enable inside
class-map inspection_default
parameters
message-length maximum 512
policy-map global_policy
class inspection_default
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
prompt hostname context
Cryptochecksum:52dc79d51910b97a2936e881ed75ec8c
: end
ciscoasa#
: Saved
ASA Version 7.2(3)
hostname ciscoasa
names
interface Vlan1
nameif inside
security-level 100
interface Vlan2
nameif outside
security-level 0
ftp mode passive
pager lines 24
mtu outside 1500
mtu inside 1500
arp timeout 14400
http server enable
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd enable inside
parameters
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
: end
ciscoasa#
17 years 2 months ago #25170
by arsrikum
Replied by arsrikum on topic Re: ASA 5505 Port forwarding setup
Hi this is Aravind .
It seems that you do not have any access-lists configured on the outside interface and there are no static translations too . With out any access lists and translations no connections form a lower security level will be allowed to an interface with higher security level . You have configured pat for outbound connections which means that if a connection is initiated from inside the reply packets would be allowed from outside and all other requests initiated from outside will not be allowed .
If you could give me a better Problem Description I can try to help you
Aravind
Aravind
17 years 2 months ago #25172
by flipzz
Replied by flipzz on topic Re: ASA 5505 Port forwarding setup
I took out my access lists and static routes because they were wrong. I was wondering if anyone had maybe a sample of setting a webserver up in the inside or something.
Thanks in advance.
Thanks in advance.
17 years 2 months ago #25173
by Elohim
Replied by Elohim on topic Re: ASA 5505 Port forwarding setup
You use static translations to do port forwarding, i.e.
static (inside,outside) tcp interface 80 10.1.1.1 80
This is an overload port forwarding. Anything coming into the outside interface on port 80 foward to 10.1.1.1 on port 80 as well.
17 years 2 months ago #25174
by arsrikum
As Elhoim suggested you can have the static statement . But you need to have appropriate access list to allow any outside traffic .
And allocate a physical interface for inside vlan .
17 years 1 month ago #25257
by flipzz
can someone point me to a config that has sample access lists and static routes for porting mail or web thru the asa? From the examples I can make mine.
