Cisco 801 ISDN Problem
18 years 2 months ago #19937 by TheBishop
I've PM'd the config for all three routers plus the output of the show versions. Is it possible this is an IOS 'feature' that might be cured by a later version?
18 years 2 months ago #19938 by Smurf
Replied by Smurf on topic Re: Cisco 801 ISDN Problem
I would definatley say try and update, there are some strange things that can happen thats often down to the IOS Image.
I will try and take a quick look at the code when i get chance (stressing about the exam already and its 5 week off, lol)
Do you not have any Cisco SmartNET Contracts on these routers ?
18 years 2 months ago #19942 by Chris
Replied by Chris on topic Re: Cisco 801 ISDN Problem
Very interesting and challenging problem you have there Bishop.
The problem can't obviously be the interconnection between the site routers since you are able to telnet to site 2 & 3's routers, so the path to them checks okay.
Since the firewalls on each site are identical and not connected between each other, it can't be an xlate entry (tcp/udp connection) waiting to expire on the firewall side (assuming a pix firewall here).
The only 'logical' conclusion here is that you've got a problem with the 801 router and possibly a bug in the IOS; Considering its a 801 - which is a very old model, its highly likely that the problem is there.
Any way you can swap it with another router for testing purposes ?
18 years 1 month ago #19945 by TheBishop
I think I agree that it's likely to be a bug/feature.
Might be able to try a different router on the test bench but then if it works there's the problem of the 'real' router(s) which are out and about in various remote locations.
Other than that I'll have to figure out a way to get a login to the Cisco site to get the latest IOS
18 years 1 month ago #19965 by Chris
Bishop,
Would you happen to know what version it is running under at this moment ?
18 years 1 month ago #19970 by TheBishop
sh version
Cisco Internetwork Operating System Software
IOS (tm) C800 Software (C800-K9OSY6-MW), Version 12.3(9), RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2004 by cisco Systems, Inc.
Compiled Fri 14-May-04 10:54 by dchih
Image text-base: 0x00195000, data-base: 0x00F6C000
ROM: TinyROM version 1.4(1)
Site1_ISDN uptime is 19 hours, 0 minutes
System returned to ROM by reload
System image file is "flash:c800-k9osy6-mw.123-9.bin"
This product contains cryptographic features and is subject to United
States and local country laws governing import, export, transfer and
use. Delivery of Cisco cryptographic products does not imply
third-party authority to import, export, distribute or use encryption.
Importers, exporters, distributors and users are responsible for
compliance with U.S. and local country laws. By using this product you
agree to comply with applicable laws and regulations. If you are unable
to comply with U.S. and local laws, return this product immediately.
A summary of U.S. laws governing Cisco cryptographic products may be found at:
www.cisco.com/wwl/export/crypto/tool/stqrg.html
If you require further assistance please contact us by sending email to
export@cisco.com.
Cisco C801 (MPC850) processor (revision 1) with 56092K bytes of virtual memory.
Processor board ID FOC0814100Z (2328318310)
CPU part number 0x2101
Bridging software.
X.25 software, Version 3.0.0.
Basic Rate ISDN software, Version 1.1.
1 Ethernet/IEEE 802.3 interface(s)
1 ISDN Basic Rate interface(s)
12M bytes of physical memory (DRAM)
8K bytes of non-volatile configuration memory
12M bytes of flash on board (8M from flash card)
Configuration register is 0x2102
Time to create page: 0.238 seconds
