Cisco 801 ISDN Problem
18 years 1 month ago #20055
Replied by TheBishop on topic Re: Cisco 801 ISDN Problem
Here's an update on the problem; some progress made:
Put the latest and greatest version of the IOS on the router and reviewed all the settings. While looking at 'show crypto map' I noticed that there is a security association timeout setting which was set to 1 hour. Changed that to two minutes and tried it again - it worked. To prove the point regressed the IOS to the original version and it still worked. So we're nearly there. I think what is happening is that the router connects to site 2 okay, but the crypto keys etc are persisting for an hour and when it then connects to site 3 (which appears to be the 'same' site as the IP address and everything else are exactly the same as for site 2) it thinks "oh, I know who you are and I'm already associated with you so these existing crypto parameters will do", an opinion not shared by the router at site 3 which has never spoken to it before. So the physical connection is there but no crypto exchange takes place, no data passes and the web page won't come up. Reboot the site 1 router (thereby clearing down all the crypto) and the crypto exchange then takes place, and bingo - the web page works.
For more info on the commands see www.cisco.com/en/US/products/sw/iosswrel...9186a00801541d4.html
I still have an anomaly though - with the security timeout at its default value (3600 sec) the ISDN inactivity timer counts nicely down to zero and the line drops as expected. But if I change the security timeout to 120 sec then something keeps poking the ISDN inactivity timer back up (something must be sending packets) so it is three or four minutes before the line finally drops. Not a show-stopper as the line does go down eventually but I would like to know why it is doing this
18 years 1 month ago #20057
by Smurf
Replied by Smurf on topic Re: Cisco 801 ISDN Problem
Can you not make sure that the associated traffic in the IPSec Tunnel is not classed as interesting traffic for raising the ISDN Line ? This then shouldn't then reset the IDLE counter ?
Just thinking out loud
18 years 1 month ago #20061
Hmm, not sure. The access lists are very simple, basically just allowing for traffic needing to go from one router to the other. And access lists isn't one of my strengths; I'll have to read up
18 years 1 month ago #20136
Just to say that the solution(s) described above have fixed the problem to the extent that we can use it. Thanks to everyone who contributed for your help with this
