My Cisco Lab Woes
18 years 2 months ago #19691
by surfer
My Cisco Lab Woes was created by surfer
First of all, just wanted to say hi and well done on creating these forums. I've used them alot but never really posted on them before.
Anyway, some time ago i bought a cisco lab off ebay and only now have i started to put it all together. However, i've run into a few problems and posted a while ago on another forum dedicated to certification to see if anyone could help out. It seems not so i thought i'd post here.
I have linked up 3 2500 series routers with 3 DB60 cables and configured them as such:
[code:1]2501 Router (Hostname: Charlie)
Serial 0 - 192.168.0.246/30 (James)
Serial 1 - 192.168.0.253/30 (Matt)
2503 Router (Hostname: Matt)
Serial 0 - 192.168.0.254/30 (Charlie)
Serial 1 - 192.168.0.249/30 (James)
2504 Router (Hostname: James)
Serial 0 - 192.168.0.250/30 (Matt)
Serial 1 - 192.168.0.245/30 (Charlie)[/code:1]
Appologies for the names...
Anyway, this only 'half' worked and it appears as though only certain links from router to router work. I spent ages testing this and came up with this:
[code:1]Clocking Receiving Works?
James Se 0 Matt Se 0 NO
James Se 0 Matt Se 1 NO
James Se 1 Matt Se 0 NO
James Se 1 Matt Se 1 NO
Matt Se 0 James Se 0 YES
Matt Se 0 James Se 1 NO
Matt Se 1 James Se 0 YES
Matt Se 1 James Se 1 NO
Matt Se 0 Charlie Se 0 NO
Matt Se 0 Charlie Se 1 YES
Matt Se 1 Charlie Se 0 NO
Matt Se 1 Charlie Se 1 YES
Charlie Se 0 Matt Se 0 NO
Charlie Se 0 Matt Se 1 NO
Charlie Se 1 Matt Se 0 NO
Charlie Se 1 Matt Se 1 NO
Charlie Se 0 James Se 0 NO
Charlie Se 0 James Se 1 NO
Charlie Se 1 James Se 0 NO
Charlie Se 1 James Se 1 NO
James Se 0 Charlie Se 0 NO
James Se 0 Charlie Se 1 NO
James Se 1 Charlie Se 0 NO
James Se 1 Charlie Se 1 NO[/code:1]
As you can see, slightly perplexing. I also tried ALL cables in the links that did work just to test that it wasn't them and it wasn't.
The origonal post i made is here so feel free to check it out. (Mods / Admins feel free to remove the link if you don't want a link to that site on your board).
I'm ready to post any outputs anyone wants!
Thanks in advance!
Thanks in advance!
18 years 2 months ago #19695
by Dove
Dove
Replied by Dove on topic Re: My Cisco Lab Woes
Hi There,
I gone through your routers config and found that there is no routing statement placed in. Enable the routing protocol on each router. (The routing protorcol would be depends on your requirement)
Dove
- smitherton
- Junior Member
18 years 2 months ago #19696
by smitherton
Replied by smitherton on topic Re: My Cisco Lab Woes
are you familiar with the ip route command? or the router rip command?
Also as I was looking at your other posts I noticed that someone mentioned setting the clock rate on your DCE to 64000, I believe that is incorrect; I have always had sucsess with setting it to 56000. This is also what Cisco recomends.
18 years 2 months ago #19726
by surfer
Replied by surfer on topic Re: My Cisco Lab Woes
Hmm well i don't really see how adding a routing protocol will help when even a basic link between the routers doesn't exist, but i've added it and it's still the same. Also added in the suggested clock rates.
The current configs look like this:
Charlie:[code:1]Building configuration...
Current configuration : 566 bytes
version 12.3
hostname charlie
boot-start-marker
boot-end-marker
enable password cisco
no aaa new-model
ip subnet-zero
interface Ethernet0
no ip address
shutdown
interface Serial0
ip address 192.168.0.246 255.255.255.252
clock rate 56000
no fair-queue
interface Serial1
ip address 192.168.0.253 255.255.255.252
router rip
network 192.168.0.0
ip http server
ip classless
line con 0
line aux 0
line vty 0 4
login
end[/code:1]
James: [code:1]Building configuration...
Current configuration:
version 12.1
service timestamps log uptime
hostname james
ip subnet-zero
interface Serial0
ip address 192.168.0.250 255.255.255.252
no fair-queue
clockrate 56000
interface Serial1
ip address 192.168.0.245 255.255.255.252
interface TokenRing0
no ip address
shutdown
interface BRI0
no ip address
shutdown
router rip
network 192.168.0.0
ip classless
no ip http server
line con 0
transport input none
line aux 0
line vty 0 4
login
end[/code:1]
Matt: [code:1]Building configuration...
Current configuration : 643 bytes
version 12.3
hostname matt
boot-start-marker
boot-end-marker
no aaa new-model
ip subnet-zero
interface Ethernet0
no ip address
shutdown
interface Serial0
ip address 192.168.0.254 255.255.255.252
clock rate 56000
no fair-queue
interface Serial1
ip address 192.168.0.249 255.255.255.252
interface BRI0
no ip address
encapsulation hdlc
shutdown
router rip
network 192.168.0.0
ip http server
ip classless
line con 0
exec-timeout 0 0
line aux 0
line vty 0 4
login
end[/code:1]
As before the only working connection is matt <----> charlie.
Cheers.
version 12.3
hostname charlie
boot-start-marker
boot-end-marker
no aaa new-model
ip subnet-zero
interface Ethernet0
no ip address
shutdown
interface Serial0
clock rate 56000
no fair-queue
interface Serial1
router rip
network 192.168.0.0
ip http server
ip classless
line con 0
line aux 0
line vty 0 4
login
end[/code:1]
version 12.1
hostname james
ip subnet-zero
interface Serial0
no fair-queue
clockrate 56000
interface Serial1
no ip address
shutdown
interface BRI0
no ip address
shutdown
router rip
network 192.168.0.0
ip classless
no ip http server
line con 0
line aux 0
line vty 0 4
login
end[/code:1]
version 12.3
hostname matt
boot-start-marker
boot-end-marker
no aaa new-model
ip subnet-zero
interface Ethernet0
no ip address
shutdown
interface Serial0
clock rate 56000
no fair-queue
interface Serial1
interface BRI0
no ip address
encapsulation hdlc
shutdown
router rip
network 192.168.0.0
ip http server
ip classless
line con 0
exec-timeout 0 0
line aux 0
line vty 0 4
login
end[/code:1]
Cheers.
- smitherton
- Junior Member
18 years 2 months ago #19727
by smitherton
Well, RIPv1 does not support subnetted networks. RIPv2 was introduced to include the subnet Mask. so do a:
Charlie
(config) #router rip
(config-router) #version 2
(config-router) #no auto-summary
(config-router) #netowrk 192.168.0.244
(config-router) #netowrk 192.168.0.252
Matt
(config-router) #netowrk 192.168.0.248
James
The"no auto-summary" command tells the router to pick up what subnet the address is on. After you issue these command do a
#show ip route
You needed to advertise the network address of the subnet your address is in. When you advertise the network address of 192.168.0.0 on a network with a 30 bit mask that address only covers a usable range of 192.168.0.1-192.168.0.2.
Let me know if this helps, or maybe you dont even want to use RIPv2 i.d.k.
Charlie
Matt
James
#show ip route
18 years 2 months ago #19732
Replied by S0lo on topic Re: My Cisco Lab Woes
Can you post the output of some example pings from router to router.
Since you have a ring here, You only need a routing protocol if you are pinging an interface that is on the third link that is not connected directly to the pinger router.
Otherwise, if you are pinging an interface on a directly connected link, it should work.
Can you also post the "show ip interface brief" output.
