Problem with CAT 5 cabling......
18 years 5 months ago #18208 by Achyutg
Are you using HUB or switch? Non- std cabling works fine with HUB but not with Switch.
18 years 4 months ago #18339 by jhun
hi
have you tried connecting the cables to other ports in your switch/hub? it may be that the fault lies on the ports of the switch/hub rather on the cables.
18 years 4 months ago #18851 by JitenderPal
most probably the cable must be faulty. try recrimpping the cable at both ends and check for the continuity.
18 years 3 months ago #19106 by smitherton
^ agreed ...sometimes my wire order loks perfect but a fresh termination is needed.
Also, purchase a cable tester, there cheap and will pay for themselves in the time you will save and the frustration you will avoid.
