- Thank you received: 1
CAT 5e CABLE PROBLEM...
18 years 7 months ago #16766
by talk2sp
BORN TO BE GREAT
c0de - 3
CAT 5e CABLE PROBLEM... was created by talk2sp
i used cat 5e 568b colouring code. but when i connect it to the network card the green light blinks continiously. when i take another wire it does not blink. what could be the problem. do i need to couple the wires again?
what did i do wrong?
BORN TO BE GREAT
c0de - 3
18 years 7 months ago #16769
by Arani
Replied by Arani on topic cat 5 cable
hi,
try recrimping the cables using the appropriate color code. you can use the procedure laid out in the firewall.cx networking section where details are given about every sort of colour coding.
cheers
cheers
18 years 7 months ago #16770
by talk2sp
BORN TO BE GREAT
c0de - 3
Replied by talk2sp on topic I TRIED CRIMPING.....
i tried crimping again but it did not work.... i used the color codes but still did not work.
n.b
the cyber cafe was poorly wired the engineer used A and B wires. which was not suppose 2 be the case. could it be a cause.
according to firewall.cx we are advised not to mix wires do u think that ccould be the cause.....
n.b
BORN TO BE GREAT
c0de - 3
18 years 7 months ago #16773
by talk2sp
thanks man....
what do u suggest now - do u think i should ignore the wire or..... cos i think the only solution is to re wire the cyber cafe which i think might not be necessarily now but someone ones said that very soon all the wires will start given problem....
thanks man waiting for ur final suggestion..
BORN TO BE GREAT
c0de - 3
Replied by talk2sp on topic THE I THINK..... I SHOULD....
thanks man....
BORN TO BE GREAT
c0de - 3
18 years 7 months ago #16774
by jwj
-Jeremy-
Replied by jwj on topic Re: CAT 5e CABLE PROBLEM...
If you are concerned about the wiring, I'd suggest investing a little in a simple cable tester. They are pretty affordable for a basic wire mapper. At the very least it'll show if you have crosses or shorts in your terminations.
-Jeremy-
