Network Latency
18 years 11 months ago #14518 by jwj
Replied by jwj on topic Re: Network Latency
Or one (hopefully) final thing, the media converters could need to be power cycled, I've been less than impressed with some models reliability in the past.
-Jeremy-
18 years 11 months ago #14531 by l0gic
Replied by l0gic on topic Re: Network Latency
I agree with jwj, media convertors don't have a great reputation when it comes to reliability. :wink:
Try power cycling them both, or replacing them if you have a spare.
18 years 11 months ago #14615 by jhun
Replied by jhun on topic Re: Network Latency
thanks to all that reply,
i have tried the ways as suggested above but i still have the same problem though... :D
well anyway, i would look into this more.
by the way, is it possible that a bad nic may cause network latency such as this one?
to give you a cleared picture, latency is felt dominantly whenever transfering or copying of files. the media converters are connected via gigabit ethernet
many thanks
18 years 11 months ago #14618 by TheBishop
Replied by TheBishop on topic Latency
Duplex mismatch often shows up only under load. Have you checked the port speed and duplex mode on both the copper port of the media converters and the switch port they are plugged into?
I notice going back through the topic that several people have mentioned checking the error counters on the ports your media converters are plugged in to. Have you done this? Try resetting the counters then running the network for a day and let us know what they record.
18 years 11 months ago #14660 by jhun
thanks bishop,
yup i've checked the counters and i found alot of RX errors. i would be contacting our provider to test the fiber itself.
i'll update you all what we find out. again many thanks.
18 years 11 months ago #14664 by TheBishop
Replied by TheBishop on topic Slowness
Ah, progress is being made.
What about the duplex mode and speed on the ports? Did you check those?
