haaalp! im late with my assignment
19 years 2 months ago #12901
by tri3axe
haaalp! im late with my assignment was created by tri3axe
Im trying to learn subnetting from the tutorial on this site but im late with my school assignment, and i still havent figured out how it all works.
The Case:
This network belongs to a company that has expanded, and sits on 3 locations.
The company is connected to the ISP in “Tønsberg”.
The Router in “Tønsberg” is connected to a Ethernet with 100 hosts.
This router also routes to and from “Bergen” wich also is connected to 100 hosts.
The “Bergen” network has 2 Routers. 1 of those routes to “Tronheim” wich also has 100 hosts
Your job is to plan IP-adresses with the origin of 172.16.0.0/16
This plan needs to contain valid series of IP-adresses for all networkcards,
Subnetmasks and default gateways
The Case:
19 years 2 months ago #12902
by tri3axe
Replied by tri3axe on topic Re: haaalp! im late with my assignment
19 years 2 months ago #13198
by d_jabsd
Replied by d_jabsd on topic Re: haaalp! im late with my assignment
Since your assignment is probably already turned in, or so late you can't get credit for it anyway, and for the benefit of other browsing the forum, you could use a /29, /30, or even a /31 for the links between the routers.
19 years 2 months ago #13201
by Jack
Jack Burgess,
Firewall.cx Staff
News Editor / Forum Moderator
www.jacksjunk.com
Replied by Jack on topic Re: haaalp! im late with my assignment
I have a problem with the last sentence:
“Your job is to plan IP-adresses with the origin of 172.16.0.0/16
Subnetmasks and default gateways “
Shouldn’t it read something like?
“I need aid in configuring my test network. I need assistance in setting up the entire network, which includes IP schema, NIC’s. Subnet masks and default gateways.
Any assistance that can help me further my knowledge so “I” can properly pass my tests and to fully understand what I’m doing would greatly be appreciated.
Thank You,
Tri3Axe “
There’s a Chinese proverb that’s reads:
“Catch a fish for a man and he is fed for a day. Teach a man to fish and he is fed for life.”
Best Regards,
Thank You,
Tri3Axe “
Best Regards,
Jack Burgess,
Firewall.cx Staff
www.jacksjunk.com
19 years 2 months ago #13204
by Dan01
Replied by Dan01 on topic Re: haaalp! im late with my assignment
Here's a link to the simplest way I found to get a grip on subnetting.
www.wildpackets.com/products/free_utilit...psubnetcalc/overview
Like Jack said, this ought to get you through your assingment, just poke around with it and at least you will have good numbers to check you calculations with.
Good Luck
Dan
Expert by NO means, LOL
Good Luck
Dan
19 years 2 months ago #13221
by havohej
Replied by havohej on topic Re: haaalp! im late with my assignment
really dont know why dont all help the norwegian guy.
when I was a student it really cost me to learn subnetting and all that stuff, now I dont really master but I defende my self in these sort of situations.
hey friend, the second diagrama where the address are placed is ok, and an idea and I think the only solution in a really situation where you really cant use any ip adress Ifor the wan sides of each location, you can use the "ip unnumbered" it uses the same ip address for the wan and lan side.
now, quoting d_jabsd you mention that for the wan you can use a /31 mask?? really??? I dont think so, but as I mentioned I dont master subnetting, so please explain me how you can use a wan subnet mask of /31???
Salute :
Salute :
