Usb stick Problem
19 years 6 months ago #10684 by aminos
Usb stick Problem was created by aminos
I want to know if there is a software that can fix or repair damaged USB Stick keys, I have a 512MB Sony micro vault usb key but it does not work proprely, when i copy things on it it copy all but when i want to copy them from the usb stick i got messages like folder damaged ..
i tried windows Scan disk, defreg but nothing changed.
Thanks for ur help
19 years 6 months ago #10685 by Arani
Replied by Arani on topic no way from here
best option is to get a new one. these are rapidly becomming consumables with no repair options
19 years 6 months ago #10734 by DaLight
Replied by DaLight on topic Re: Usb stick Problem
Have you tried reformatting the disk?
19 years 6 months ago #10743 by aminos
Replied by aminos on topic Re: Usb stick Problem
yes i formated many times but the problem still exists :cry:
19 years 6 months ago #10745 by DaLight
If you've tried it with other PCs and it still does the same thing, you may have to follow Arani's advice and get a new one. :(
19 years 6 months ago #10748 by Rockape
Replied by Rockape on topic Re: Usb stick Problem
Have you got it locked. Check the switch on the side, and see if this makes any difference.
